Old 11-14-2004, 09:16 PM   #1
BurnoutNova
BurnoutNova's Avatar
69 custom camper 20!!! cab swp info HELP
ok, i lined up buying a 69 3/4 ton custom camper today, should be picking it up tomorow.
its a nice body, no drivetrain, no title...
sooo, i want to swap this cab to my 71 K-10, i know i'll need to cut the floor and use my hump for the 4x4 shifter, but what else will i need to change...
are the brakes the same, (booster, and the way it mounts) are the cab mounts the same, what about any wiring issue i might have?
i plan to use evrything from my tuck (guages, wiring, column, and so on).
just want some tips to avoid any delays later on..
THANKS, zach
BurnoutNova is offline   Reply With Quote
Old 11-14-2004, 09:41 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there will be a throttle rod on the 69 while your 71 will be a cable...the booster will need swapped, but I think the mounting will be the same, the floor hump as you mentioned...
The cab mounts should be the same. Only the 1/2 ton 2 wheel drive is different.
Old 11-14-2004, 11:38 PM   #3
BurnoutNova
whats diffrent about them???
i thought the cab mounts were all the same???
but just to be clear, this is a 69 3/4 ton 2wd cab... going oin a 71 4x4 frame
Old 11-15-2004, 12:04 AM   #4
Longhorn Man
1/2 ton 2 wheel drive trucks had a shorter cab mount then any 4X4, any 3/4 ton or any one ton.
Old 11-15-2004, 12:31 AM   #5
BurnoutNova
so for my application, it should be alright?
do you mean the frame holes, front to bacl are longer on a 4x4 and a 3/4ton? why?
please excuse my n00b questions, i dont know anything about cabs and such
zach
Old 11-15-2004, 12:35 AM   #6
BurnoutNova
sooo, i can swap my cable from the 71 to the new cab without probleoms, right?
and the boosters i saw already, will it bolt up to the same spot, i'll just need to use my brake pedal rod and stuff?
thanks again... im a n00b
Old 11-15-2004, 01:06 AM   #7
Longhorn Man
zach
Just the rubber cab mount it's self is taller than the 1/2 ton 2 wheel drive. You're OK on this.
The throttle rod/cable is not an easy swap, the firewall is stamped differently. Either cut and weld, or get a rod for the new cab.
Your brake pedal assembly is fine. just hook the later booster to it in the same location as the old one.
Old 11-15-2004, 01:33 AM   #8
BurnoutNova
i think i'll try and get the cable to work... i had a 69 K-20 last year, and it stuck on me once... it sucked! im not a big fan of the throttle RODS at all.
now that you mention the body mounts being taller, does that mean the mounts where tha front clip and box mount are taller, or is the cab mounts "higher" in the cab... is there any way someone could post pics??? i know i'll be aight, but im just curious.
hows come they made the 4x4 and heavyer trucks diffrent, is it better that way?
zach
Old 11-15-2004, 04:46 PM   #9
Longhorn Man
if your rod was sticking, you probably had it hooked to the carb wrong, or a bad motor mount was making it bind.
I am 99% sure the other mounts will be taller too.
taller mounts...NFC as to why.
