Old 11-14-2004, 10:25 PM   #1
70 shorty
Where's my beer?
70 shorty's Avatar
converting from idiot lights to guages
I'm sure this has been covered a million times (1000001 now), but I couldn't find any info on it. I have a factory gauge cluster and would like to swap out the idiot light cluster. Where do I go to find out how? I didn't see anything under FAQ's.
70 shorty is offline   Reply With Quote
Old 11-14-2004, 10:28 PM   #2
dinnut
dinnut's Avatar
http://www.gmcpauls.com/Tech%20Tips1.htm
try that page! i learned the hard way about installing a non gauges harness with a gauges dash. all kinds of weird stuff happens.....
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-15-2004, 12:20 AM   #3
68speedalert
Semi-Senior Member
68speedalert's Avatar
It is true. The connector will hook right up.....don't do it as the two units are completely wired different. Check that site and follow it closely. Take your time and check it twice. Failure to do it correctly will let the smoke out of you new gauge set.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 11-15-2004, 02:01 AM   #4
longhorn71
longhorn71's Avatar
that conversion is great.i did it in about an hour.lots easier than swapping all the wiring
longhorn71 is offline   Reply With Quote
Old 11-15-2004, 04:17 AM   #5
BurnoutNova
BurnoutNova's Avatar
i did it in the 69 i had, but i put a camaro tach in at the same time. it was a little tricky to get the stock printed circuit to work with the tach, but it did...
and guages are WAAY better than the idiot lights, best thing i ever did to that truck.
BurnoutNova is offline   Reply With Quote
Old 11-15-2004, 01:08 PM   #6
70 shorty
Where's my beer?
70 shorty's Avatar
Thanks guys, printing the page off now, so I can reference it when I make the conversion
Old 11-15-2004, 02:00 PM   #7
Jakes-66-K10
Jakes-66-K10's Avatar
Maybe I'm missing something but does someone have a pic comparing these dashes? What does an idiot light even look like?? I've only seen gauges
Jakes-66-K10 is offline   Reply With Quote
Old 11-15-2004, 02:09 PM   #8
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
picture your dash without the 4 smaller bottom holes. and where the tach goes there is blinkers, generator light, and water temp lights. on the gas gauge side there is brakes, and something else, oil maybe.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-15-2004, 02:13 PM   #9
Jwill41
Jwill41's Avatar
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
