11-14-2004, 11:17 PM | #1 |
Replacing trim
Am restoring a 70 swb chevy and have ordered the new trim fastners for the trim. For the life of me I cant figure out how to install the trim(lower wide trim). Is there any place I can go on the internet that will show me(pictures) how to do this. New here and hope I can get a lot of help here.
11-15-2004, 08:29 AM | #2 |
Welcome to the board from West Michigan!
Do you have the holes in your truck for mounting the trim or is that what you are needing to do? I only use trim clips with the studs on them so that the stud goes through the sheet metal and is held in place with a nut. Are your clips set up with studs or are they the glue on style? Jim |
11-15-2004, 10:42 AM | #3 |
Thats the Hillbilly way
If you can get a LMC catalog it has some great pic,s
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
11-16-2004, 01:46 AM | #4 |
Lovin' Life in Miss.!
First off, Welcome from Northern California!!!!
If you use the push on clips do a test fit before you drill any holes!!!! Clips that came with mine were 5/16". Holes I drilled were 3/8"!! Clips are installed in moulding by bending the leg back against itself and inserting in the molding. If you just pinch it with finger and thumb and let the sring tension hold it... You did it wrong.
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 11-16-2004 at 11:09 PM. |
11-16-2004, 02:08 AM | #5 |
Here are some pics of the upper moulding. I was shown how to do the upper by my body guy. I never learned how to do the lower. Sorry.
Edit: Just re-read yout post and I was absolutely no help!!!! Anyone else?
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 11-16-2004 at 02:11 AM. |
11-16-2004, 02:19 AM | #6 |
These are my best guesses. I like pic 1 best.
The truck... you hear that? No really, you did hear that?!!! |
11-16-2004, 07:30 AM | #7 |
The factory mostly installed the clips like pic #2. That is the oreintation that we use on the clips, also.
Jim |
11-16-2004, 11:42 PM | #8 |
Thanks guys. Most of mine will be the stud kind. Hopefully I will be able to get the nuts on most of them.
