Old 11-15-2004, 10:44 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
72 C30 dually rolling chassis
I'm parting it out: 133" wb frame w/ front end and dually rear. 5.13 gears. SM465 tranny and driveshafts all there. Truck had a 350(no motor now) was a wrecker. I'm keeping the cab and front clip. Has a 8' stepside bed on it, but it is trash and I'm removing it. Has 6- 16.5"x6.5" rims w/ 8.00-16.5 tires. Some pics in the link in my sig(red and white truck) and will take pics of any items of intrest. $350 for whole chassis or I will part it out. Local pick up.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-15-2004, 05:55 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
TTT FOR YA , WISH YOU WERE CLOSER , NEED A SWB STEPSIDE
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-15-2004, 10:12 PM   #3
Rod
Well.... hmmm local pickup eh! .... could be interested in a rotor and the rear drums if you'll ship. They gotta measure within tolerance though... drums fail at 13.090. discs fail at 1.215.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-16-2004, 12:40 AM   #4
1969 GMC
1969 GMC's Avatar
Jim, PM sent.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-16-2004, 07:52 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Rod, I'll measure them. Adam, replied.
Old 11-17-2004, 07:11 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Solid driver side fender ($75) and inner fender ($50). Both for $100. I have a used box to ship the fender in but not the inner fender. These are plus shipping.
Old 11-18-2004, 09:48 PM   #7
Rod
Figured I'd ask about the front rotor too...fail, is thinner than 1.215...are these 9/16 studs also?
Old 11-19-2004, 07:46 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Rod, they are 9/16 studs. I'll pull a tire today and measure the rotors. I just got the front clip removed and shift gears to but the "new" metal on my 71.
Old 11-19-2004, 09:24 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Rod, trying to locate the proper measuring tool, but here's a shot of the front suspension:
Old 11-19-2004, 09:33 PM   #10
Rod
A 1 to 2 inch micrometer will do it. Mind you it's not that acurrate if there are wear patterns in the rotor.
Old 11-19-2004, 09:41 PM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
They seem fairly smooth, light surface rust from sitting. There is a grove that runs in the center on both sides and on both rotors. My 71 has the same grove. I only had a 0-1" micrometer, and my neighbor with everything has not been home this evening.
Old 11-20-2004, 08:57 AM   #12
toddtheodd
The oddest Todd around
toddtheodd's Avatar
My 72 has that same groove as well. Both sides of both rotors. Is that supposed to be there???
toddtheodd is offline   Reply With Quote
Old 11-20-2004, 09:42 AM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Supposedly it was an attempt at cooling. Or helps keep the pads centered on the rotor.
Old 11-20-2004, 11:57 AM   #14
Als454
I am looking for a set of Custom/30 emblems. If you have them!
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 11-20-2004, 06:39 PM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Al, Both broken.
Old 11-22-2004, 12:09 PM   #16
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Hey all you longhorn owners w/ 3spds, everything you need to convert to a 4spd:
tranny crossmember, tranny, high hump, driveshafts and carrier bearing. $200 plus ride.
