Old 11-15-2004, 02:22 PM   #1
sure_green
Body Panel Alignment Problem
Hellow Guys,
Have any of you been face with a rear panel that did not align properly with the door because of body mount? I am looking a blazer that has about an 1/8 of an inch gap between the top weather strip and the window (when it is let all the way up). I am wondering could it be a worn out body mount.
I know it could be several other things, but what are the chances of the body mount being one of them. I will welcome all other possibilities.
sure_green is offline   Reply With Quote
Old 11-15-2004, 03:10 PM   #2
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
On a Blazer, the body mounts have a LOT to do with alignment. I can tell you first hand, as I am sure others can to. Not sure in this case.
Mine had a problem where the regulator was binding and not allowing the window to reach the weather stripping properly. The window SHOULD go all of the way to the top of the door frame. If there is a gap there, your regulator is not allowing the window to go all of the way up. I just loosened some things, adjusted some things, and then the window made it's way to the top of the track properly.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 11-16-2004, 04:44 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
According to the factory assembly manual, the body bushings have as much to do with alignment as the actual bolt up. So, go with a new bushing kit and that should fix it for you. If not you can shim as necessary to offset the spacing. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
