Does anybody know the gear ratio of A 69 chevy 3/4 ton 396 Turbo-400 trans. The truck is all stock.
![]() Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
its all about the +6 inches
3.54 more likely than not.
Longhorn Man Would you know the gear ratio in my 70 1/2 ton 4-speed (original truck trans).350 engine. THANK YOU VERY MUCH!!!!!
![]() Gary
3.07 acording to the books.
Cantankerous Geezer
I thought the 3/4 ton only had two choices. 4.57 with the 4 speed, 4.10 with the automatic.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
If it has an Eaton rear end it could have 4:11's, mine does. Originally had a 350/TH350, now has a 350/TH400.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 11-15-2004 at 11:09 PM. |
the big block trucks usually got the dana, and acording to the GM catalogs, came standard with the 3.54 gears. I would have to look, but I don't remember seeing an option gear for 396/402 trucks.
This is why I would give my left nut for a one ton big block rear axle. Caddys don't like to rev up much. |
#8 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
OK...let me rephrase....
I would give my left nut for one in my area that is affordable. There...I feel better now. |
Andy, I thought the dana 60 only came in the 3/4 ton trucks and the 1 tons all got the Eaton HO72.
Oh, and PM sent. ![]()
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Hmmmm, right you are.I'll have to look up the one ton big block stuff tomorow.
Good catch. |
