Old 11-15-2004, 07:06 PM   #1
GROUCH
A/c Cab And Other Parts In Texas F/s
I HAVE A 70 CST A/C CAB IN TEXAS F/S. IN PRETTY GOOD CONDITION BUT NEEDING THE NORMAL CAB CORNERS AND OUTER ROCKERS. FLOORS IN GREAT SHAPE. WINDSHIELD GONE BUT BACK WINDOW IN PLACE. CAB HAS MOUNTS ON ROOF FOR RUNNING LIGHTS. ALSO HAD CARGO LIGHT(GONE). DASH IS UNCUT, BUT P.O. CUT 4" HOLES IN REAR PILLARS FOR SPEAKERS. HAS ONE SMALL DENT RIGHT BEHIND FILLER NECK HOLE. CAB STILL BOLTED TO FRAME. DOORS ARE GONE. HAVE CLEAR TEXAS TITLE. ALSO HAVE THE GAS TANK. ASKING $300.00 OBO
ALSO F/S IS THE REAR END. IT IS A LEAF REAR AND HAS BEEN CONVERTED TO 5 LUG USING 71 AXLES. NEW OUTER BEARINGS AND SEALS. STILL BOLTED TO FRAME, YOU CAN TAKE LEAFS OR OR NOT YOUR CHOICE. ASKING $100.00
I ALSO HAVE A SET OF STEEL SADDLE TANKS THAT CAME FROM SAME TRUCK. ASKING $50.00 FOR PAIR
ITEMS LOCATED IN ABILENE TX AND FOR PICKUP ONLY. CAN TAKE PICS IF IT EVER STOPS RAINING. E-MAIL IS mewdew_13@hotmail.com
GROUCH is offline   Reply With Quote
Old 11-17-2004, 06:35 AM   #2
GROUCH
Ttt
Old 11-20-2004, 09:37 AM   #3
GROUCH
Ok How About $200 Obo For Cab. And I Found A Set Of Ram Horns From A 307 Out In The Barn. Forgot I Had Them.
Old 11-20-2004, 11:29 AM   #4
2low72
Where at in abilene is it located?
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 11-20-2004, 01:10 PM   #5
GROUCH
Just Outside Of Abilene On Old Anson Road Headed Toward Hodges. If Your In Town Give Me A Call At 370-0071.
Old 11-21-2004, 08:45 PM   #6
2low72
What gears does the rear end have? And how do the saddle tanks mount under the truck(might be interested in them)?
Old 11-21-2004, 08:52 PM   #7
GROUCH
I Don't Know The Gear Ratio Offhand. What Is The Easiest Way To Tell?. The Saddles Mount Forward Part Of Bed Using Long Carraige Bolts And A Cross Brace. If You Are In Abilene Give Me A Call And Come Out And Look At Them. I Get Off Work Out At The Af Base At About 4 Pm.
Old 11-21-2004, 09:48 PM   #8
2low72
I'm a c-130 crew chief at dyess, but we work different shifts. I'll call you when I get a chance. I'm not sure how to tell the gear ratio. I'll start a new thread and find out.
Old 11-21-2004, 09:58 PM   #9
GROUCH
I'm The Lead Pro Super Down In The 9th Amu. I Spent 20 Years On Herks. Give Me A Call, We Can Try To Hook Up Before I Deploy.
Old 11-21-2004, 10:01 PM   #10
2low72
you wouldnt happen to be Mark Washburn would ya?
Old 11-21-2004, 10:24 PM   #11
GROUCH
That's Me. Who Is This?
Old 11-21-2004, 10:27 PM   #12
2low72
I was stationed with you at Moody, I'm Tyler Schmidt Rusty's friend
Old 11-21-2004, 10:30 PM   #13
GROUCH
Well Give Me A Call And We'll See What You Need That I May Have Out Here. 370-0071
Old 11-21-2004, 10:31 PM   #14
2low72
No problem..Talk to ya later
Old 11-26-2004, 12:51 AM   #15
GROUCH
ttt
Old 11-26-2004, 10:22 AM   #16
2low72
I will call ya this week some time. i'm in ft. worth this weekend, but next week will be on days so hopefully i will be able to come out there and see what you got.
Old 11-28-2004, 11:04 PM   #17
GROUCH
Ttt Again
Old 12-11-2004, 08:29 PM   #18
steve75104
Another 69-20 years later
pm'd ya
steve75104 is offline   Reply With Quote
Old 12-11-2004, 08:37 PM   #19
Larry68GMC
Ever figure out what gears were in the rear end?
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
