Old 11-15-2004, 11:50 PM   #1
BurnoutNova
BurnoutNova's Avatar
leaf spring dana 60?
well, the parts truck i got is a 2wd 3/4 ton, and has a leaf spring dana 60 rear in it. not sxure on the gears...
is it worth anything at all? i was thinking it was a plus, just because it would be worth more at the metal yard... for weight!
should i take it to the junkyard, or try and see if anyone can use it?
zach
BurnoutNova is offline   Reply With Quote
Old 11-15-2004, 11:57 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'll bet it was a big block truck....if so, 3.54 gears should be in there.
Damn shame you are so far away.
Old 11-16-2004, 12:45 AM   #3
cheyenne10
cheyenne10's Avatar
Leaf dana 60
I have a leaf dana 60 but no BB, never was, wish it had one
I think mine is 4.10 open version behind 350/350 stock, still way better in my opinion that eaton version.
Bob
cheyenne10 is offline   Reply With Quote
Old 11-16-2004, 06:02 AM   #4
Longhorn Man
350/350 should have a 4.10....in an eaton or a dana.
Old 11-16-2004, 06:10 AM   #5
OhioDan
OhioDan's Avatar
Mine had a 4.10 in it also. Changed it to a 3.54 for better mileage.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-16-2004, 09:47 AM   #6
Chris H
72 C30 Trailer Queen
Chris H's Avatar
On the subject of Dana 60 rears, I have a leaf spring rear that has a 4.10 posi.
What kind of posi was used in these?
Can the posi be used if I switch the gears to 3.54?
Is it worth anything as is?
Chris H is offline   Reply With Quote
Old 11-16-2004, 10:34 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The posi was the powr-loc made by dana. I've seen it refered to as the tightest posi available short of a true locker. Not sure of the carrier break for the dana 60, don't know if it will work w/ 3.54 gears. The powr-loc can be rebuilt and clutches added to tighten it up. I have the manual(dana 60/70 powr-loc) if you need a copy.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-16-2004, 11:57 AM   #8
LT4XTREME
Around here that dana 60 would sell quick and for a good chunk of change. There is a lot of 4x4 mudder trucks around here that love to break axles and mangle sheet metal (that happens with bigblocks and 44" tires). Thats not my cup of tea I would rather build something nice and keep it that way. If that dana 60 has the brake drums that can be removed without removing the axles (there will be some countersunk screws thru the drum inbetween the studs) that would make it a even better find. It would defiantly be worth more to someone than to sell it for scrap.
LT4XTREME is offline   Reply With Quote
Old 11-16-2004, 12:46 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It appears that the split was 4.10 and numerically lower(3.54) case. With a 4.10 gear set available for the 4.56 case.
Old 11-16-2004, 01:28 PM   #10
john@thepier
john@thepier's Avatar
I have a leaf spring dana 60 410posi rear and I haven't sold it yet on this thread ,I was asking $300 for it then $200 so I don't think yours will not be worth much here.maybe its just location for the other members.then again look at TXfirefighters truck hasn't sold either and its a steal at the price he wants.maybe everyone here would rather hold onto there money and let the good deals pass by.
john@thepier is offline   Reply With Quote
Old 11-16-2004, 02:49 PM   #11
BurnoutNova
i dont think its a big block truck... but i havnt checked, so im not 100%
are the leaf spring dana 60's all the same? or are 4x4 and leaf 2wd diffrent?
so anyone interested in this?? i'll let it go for next to nothing... just to get rid of it.
Old 11-16-2004, 08:26 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The only difference is the spacing of the springs. the 2wds are wider spacing than the 4wd frames. Randy70c-10 has a 2wd 3/4 ton w/ a dana 60 and the spring pad spacing is wider than that of my dana 60 in my 70.
