Old 11-16-2004, 01:26 AM   #1
wolfthing2000
Ring and pinion set up
I have to replace the ring and pinion in a K-20 front axle since I changed the rear from a 4.56 to a 4.10. Is the front a 4.10 exactly also or is there a slight difference in ratio ( say 4.09) to keep the front axle pulling a little more to keep the truck going in a straight line when it is slippery???
Where on- line does anyone show the ring and pinion set up procedure for a Dana 44?
I am a Machinist and understand the process and feel I can accomplish the task.
Any info is highly regarded.
Thanks,
Dave
wolfthing2000 is offline   Reply With Quote
Old 11-16-2004, 03:48 AM   #2
75-K5
Bucket of Bolts
4.09, 4.10, and 4.11 rear and front ends will all work together, since there is enough drivetrain slack, tire slippage, etc to make them virtually the same ratio.
This is the project that never ends, yes it goes on and on my friend....
75-K5 is offline   Reply With Quote
Old 11-16-2004, 10:39 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yea I believe people just cling to 4.10 and 4.56, I believe the eaton rear is actually a 4.57 and my dana44(GMC) front has 4.09 gears. Now I believe you can have 4.09 gears and 4.11 gears in a dana 44, which brings up the next question: where is the carrier break for a dana 44? And which gears are used for with each carrier. i.e are 4.09 gears/carrier used w/ lower gears (say 4.56) and the 4.11s with higher gears like 3.73 because the carrier is different?
As far as setting up the gears I understand the big thing w/ the dana44 is the diff bearings are pressed on and might have to be removed/installed several times to get the gears adjusted correctly. I do not have the procedure but you can check over at www.coloradok5.com I believe it is posted in the tech section.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-16-2004, 11:54 AM   #4
smokekiki
Mike
smokekiki's Avatar
I think 3.92 and higher numbers,ie 4.09 411 and so on are the same carrier.Anything under is a different carrier.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 11-16-2004, 12:39 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I did some research and it is 3.92 (like smokekiki said) and higher(4.10) also 4.09 and 4.10 is available just the ring gear is thicker than the other. This was out of the Reider Racing catalog.
Old 11-17-2004, 01:15 PM   #6
wolfthing2000
still searching for something specific to the dana 44
Old 11-18-2004, 12:36 AM   #7
wolfthing2000
ttt
Old 11-18-2004, 01:15 PM   #8
elk hunter
just use the same shims that are already there. unless the pinion shim is spun, you will be just fine. are you selling the 4.56's?
yeah, but how's it wheel?
elk hunter is offline   Reply With Quote
Old 11-18-2004, 02:18 PM   #9
RON WOODGEARD
Resident Young Old Dude !
Find a site or Tech article that explains how to change the gears and how to set the "Backlash" up.. If you don't do it right you'll blow the gears.
There are books that describe it, and I remember seeing a set that someone put together that had everything in it to do the install. ALong with a VCR that showed it.. It's been a few years ago, but I'm sure someone still sells it.
It's not hard, It can be time consuming, installing and removing the gears until they are set up right...
RON WOODGEARD is offline   Reply With Quote
Old 11-18-2004, 10:09 PM   #10
Rod
http://www.differentials.com/install.html
That site has a good article on diff gear set ups.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
