Old 11-16-2004, 05:23 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
carb linkage
My 69 K20 has the hard linkage to the carb. I need the linkage that connects to the carb to be about 3" longer.
The rod is right about 10" long and 1/4" diameter but it is a fine thread and I haven't found anything like it yet. Needs to be about 13" or so long.
I see a couple options assuming I can't find a connector and some all-thread to lengthen it:
1. Cut it and weld in a piece of rod in the middle to keep the end thread correct.
2. Tap the piece it goes into to 5/16" and use a piece of 5/16" all thread.
Let's here some suggestions or other recommendations. As always cheaper better but don't want to end up looking like a hack job.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-16-2004, 06:02 PM   #2
Harold Shepard
i have a longer rod that came off of brother's 70 lwb 350 truck. It is 1/4 etc.. If you are interested shipping will get it to your house. Harold
Harold Shepard is offline   Reply With Quote
Old 11-16-2004, 06:05 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Solution 1. Use your eyeballs and place a line in space between the carb linkage and your right hand in the cab. Drill a hole along that line. Then take a piece of baling wire connected to the carb linkage, through the firewall and dash so you can pull it with your right hand. Instant Throttle, and it's cheap!
Solution 2. Replace the linkage with a cable.
Solution 3. Weld a piece in the middle of the linkage.
Solution 4. Take the truck back to the painter and tell him he didn't finish. Just be ready to streak next fall. :p
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-16-2004, 06:18 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Harold, I will pm you - thanks.
Old 11-16-2004, 08:08 PM   #5
crazy longhorn
Fabricate till you "puke"
A couple guys posted pics a while back.....use all thread , with rod ends & slip a pc of tubing over the threaded rod to "clean it up". It will be a very slick looking & funtional pc (fairly cheap too) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-16-2004, 08:29 PM   #6
JimKshortstep4x4
Smile
The rods are easy to make using 1/4" rod, threading the one end and drilling a cotter pin hole in the other after bending it.
The problem is that the fitting is not national fine thread but a different thread count so what I have done is rethread the fitting with a 1/4-28
tap.
Jim
Old 11-16-2004, 08:50 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
:p
LMAO redneck it together
I would send Harold a few bucks
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-16-2004, 11:10 PM   #8
3 on the tree
Why not weld a new arm to your firewall bracket that sticks out the 3 inches? Paint it and I think it would not be noticed,but that's just me
3 on the tree is offline   Reply With Quote
Old 11-16-2004, 11:40 PM   #9
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i cut mine and welded a chunk in. but i am thinking about getting a peice of round stock and threading each end and threading on the ball joint swivel thing-ma-bobbers. (i think thats what they are called )
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-17-2004, 12:53 AM   #10
breeh
Recovering 67-72 Addict
breeh's Avatar
I used a throttle rod for a 1967 BBC Camaro (available from Classic Industries). It fits perfectly.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-17-2004, 08:33 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Originally Posted by 68w/sbc406
..... i am thinking about getting a peice of round stock and threading each end and threading on the ball joint swivel thing-ma-bobbers. (i think thats what they are called )
heims ends or rod ends is what you're thinking of.
I get them at Summit for like 4 bucks each. They make real good throttle linkages when coupled with a threaded length of 1/4 rod.
Old 11-17-2004, 08:59 AM   #12
theo70
COMING SOON...
theo70's Avatar
I rednecked my linkage with a length of coat hanger, slipped a bit of new brake line over it, & tied off the ends. A good "long-term temporary" solution.
theo70 is offline   Reply With Quote
Old 11-17-2004, 11:36 AM   #13
68w/sbc406
68w/sbc406's Avatar
yeah whatcha-ma-whosents
