11-17-2004, 04:45 AM | #1 |
Gas Tank Question
Will a 1972 Suburban gas tank replace a 1972 Blazer gas tank?
I have a 72 Blazer coming in that needs the tank replaced. I have a 72 Suburban tank I was going to put under my 9 foot stepside truck, but never did. Will it work? Anyone done this? Thanks, Don |
11-17-2004, 08:36 AM | #2 |
Believe the burb tank will fit fine. May have to change senders as I recall something about the ohm's difference. May need to swap out straps and filler hoses as the tank filler might be a bit different. Let us know how it works out. Huck
11-17-2004, 10:24 AM | #3 |
The tanks are the same, you will have to switch the filler necks though, they are bolted on and solder on so you need to use a propane torch to get them off.
11-18-2004, 01:20 AM | #4 |
Sounds good! Thanks!
