Old 11-17-2004, 10:21 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Speedo question/problem
I have been driving my 70 4x4 this week. Been doing alot of work to her to get her ready for my wife to drive to work when the weather turns bad.
I noticed that the spedo is off exactly 5mph compared to my GPS. Nothing surprising there. But I have noticed that every once in awhile, it will just drop about 5mph, then go back up. The needle doesn't really bounce, just out of the blue it will drop for 5 seconds to a minute, then pop back up.
I am sure the 5mph off thing is in the calibration, but is the up and down thing a bad speedo? The odometer quit working years and years ago, so I wouldn't feel bad about throwing another one in there.
Thanks for any suggestions. Also, anyone know the weight of a complete disc brake front crossmember?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-17-2004, 10:32 AM   #2
JimKshortstep4x4
Smile
Sounds like the speedo is bad. I would try replacing it first. If it were a cable or gear problem the needle would bounce.
Jim
Old 11-17-2004, 10:42 AM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
5mph off at ALL speeds? That's not a calibration error (or at least, not as far as speedo gears in the transmission are concerned). The gap should widen as speeds increase.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-17-2004, 10:47 AM   #4
glock35ipsc
Yeah, it is off by 5 at all speeds. If it says 25 the GPS says 30, if it says 55, the GPS says 60. The GPS is dead-nuts on compared to the speedo in my 03' Silverado, so I trust it. I have an extra speedo in the attic, I guess I'll put it in this weekend and see what happens.
Thanks guys!
Bob
Old 11-17-2004, 12:02 PM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
the speedo should be off by a % not a constant 5. as for the complete crossmember thing, they are heavy. it was all me and a friend could do to get it off of the ground to put it on jack stands
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-17-2004, 12:24 PM   #6
ale8oneboy
ale8oneboy's Avatar
Would a different tire size affect this?
MEMBER OF THE BUCKET SEAT CLUB (REAL BUCKETS)
"Color Me Gone" - Two Lanes of Blacktop
ale8oneboy is offline   Reply With Quote
Old 11-17-2004, 12:27 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
It could be a zero error. The odometer issue is probably a plastic shaft inside the housing. I just had my speedo gone through at Bowtie Bits. Cleaned, calibrated, replaced the odometer shaft and painted the needle for $45. He has the work done in his shop.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-17-2004, 12:43 PM   #8
68w/sbc406
68w/sbc406's Avatar
tire size, and gearing can effect this.
Old 11-17-2004, 12:48 PM   #9
glock35ipsc
The truck has stock heigth tires and original gears. I think I will replace it with another speedo I have and go from there. I am not too concerned about fixing this one since the odometer quite working about 40,000 miles ago Thanks all!
Bob
Old 11-17-2004, 01:23 PM   #10
Project1970
14.1 @ 96MPH
So does it actually read zero when stopped? It sounds like it should read 5mph then.
Yeah, the gauge itself is most likely broken.
Old 11-17-2004, 02:21 PM   #11
glock35ipsc
Yup, it reads zero. It seems to be off right from the start though.
Bob
