Old 11-17-2004, 12:18 PM   #1
avejoe
Custer had a plan too.
avejoe's Avatar
Open to Posi Rear Conversion- How?
I have a 72 K10 GMC with a leaf spring readend. When I spin one wheel the other spins in the opposite direction so I believe I have an open or non-posi rearend.
What is the most efficient and cost effective way to convert it to a posi?
What is the technical difference between a posi and a locker?
Thanks!
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 11-17-2004, 01:45 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Don't know about a locker but you need to know what gears you have or planning to use and buy a posi unit compatible. I paid $280 for my eaton.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-18-2004, 01:33 PM   #3
elk hunter
if you drive your truck on the street you want a limited slip diff. if it is for off road, go with a positive locking diff. thats not to say that you cant use a locker on the street, they can just be a little noisy and give you some front end push or under steer. once you get used to the driving charatoristics, i think you will like the locker. i have a locker in my 72, and have a samurai with lockright lockers front and rear. if you go with a lockright, you can use your carier. the instructions are easy to follow and in about an hour, you can be done. good luck!!
yeah, but how's it wheel?
elk hunter is offline   Reply With Quote
Old 11-18-2004, 02:01 PM   #4
jet mec
I want to do the same thing. I know nothing of the subject. But I am about to learn. I think I may go with a mini spool, but I'm not sold on it yet. I want to drive it once in a while as well as race it.
jet mec is offline   Reply With Quote
Old 11-18-2004, 02:16 PM   #5
Super Duck
Chevy Nuttttt
Super Duck's Avatar
the only way a spool is good on the street is if you like to brake parts
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-18-2004, 02:24 PM   #6
jet mec
I don't want that to happen. I guess I'll keep it off the street, and on the track...
