Old 11-17-2004, 02:19 PM   #1
MrGoodpliers
MrGoodpliers's Avatar
Master cylinder/Prop valve problem?
I put disc brakes from a '71 on my '69, and while I was rigging up my lines I took the fitting off of the back of the proportioning valve to the parts store so I could get the right fitting. A bit of stuff was in there, I'm guessing residual valve parts . Anyway, I think I have it back together the way it was but I can't get any fluid to move through the rear of the master cylinder. I took the line off the prop valve and blew air through it, lines not clogged. Pressing the pedal with the line off, I can hear air/suction but no fluid. Any ideas?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 11-17-2004, 02:20 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Did you bench bleed the MC?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-17-2004, 02:30 PM   #3
MrGoodpliers
Nope... How do I do that?
Old 11-17-2004, 02:58 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
click here
Old 11-17-2004, 03:01 PM   #5
STEVE A WILBURN
Put Your Mc In A Vise. And Fill With Brake Fluid And Use A Screw Driver And Push On The Place Your Brake Peddle Rod Goes In Until You Get All The Air Out.
JUST HAPPY TO BE ALIVE.
STEVE A WILBURN is offline   Reply With Quote
