Preference/favorite brand of ignition components
I'm up for cap, rotor, plugs, and wires once again- on both vehicles, actually. I've just used the NAPA (Niehoff, Echlin, Belden) stuff on the Chevy in the past. I'm sold on AC plugs in everything I run, so that's set in stone. I'm not looking to mod anything, just replace stock components.
But, I thought I'd ask: what brand(s) of ignition components do you prefer and, if possible, why? A list of possibilities: -OEM (GM, Mopar) -Mallory -NAPA (Niehoff, Echlin, Belden) -MSD (stock components) -Prestolite -Blue Max -Summit -Etcetera BTW, I've already ruled out Accel and SplitFire... Kevin 1986 Chevy Suburban 1998 Jeep Wrangler
Semper Paratus |
Slots go on anything!
They sell AC Delco stuff at Oreilly's. That would be my first choice. They also have a Borg Warner line of stuff with a lifetime guarantee that have heavy brass contacts, and look pretty sturdy. I would avoid the house stuff from the larger chains like the plague. Even if they hava a lifetime guarantee, I don't need the practice of changing a cap, rotor or wires.
I have used the 8.5mm MSD wires from Summit very satisfactorily as well. Very nice part.
1974 Jimmy- 5.3/4L80e/NP241 |
![]() Join Date: Feb 2004
I just recently changed out the distributor cap, rotor, and plug wires on my 76 with Borg Warner stuff from OReilly's and I've been happy so far. My coil was ok, so I just moved it over to the new cap and was good to go.
I've only had 1 problem with Borg Warner since I started working on my truck about a year ago, and that was with a bad Temp Sending Unit. OReilly's swapped with me with no hassle, but there was plenty of hassle in changing it twice. Mike ![]() |
MSD all the way for me, and ac delco plugs
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
i would just go with ac delco for stock replacement
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Cap/Rotor/Coil = Hypertech Power Coil Kit
Wires = MSD 8.5mm SuperConductor's |
STILL PLAYS WITH TRUX
I use A/C DELCO stuff
I also use a cap & rotor made by STANDARD and its called the Blue streak it has copper or brass inserts for better conductivity and the cap is made from a high quality resin. http://www.bluestreak.ca/english/ |
OutOfMyMind & I'llNeverKnowWhy
Moroso Blue Max wires, AC spark plugs and the red Conrad dist cap and rotor from Autozone.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
Im a big fan of MSD. I also like Accel coils & cap/rotors. I usually use Motorcraft plugs(I know,I know
Right turn Clyde
Bluestreak is good, Borg-Warner is good ac delco is good. Most stuff like modules I get are ac delco. I use ac-delco plugs and thought about NGK plugs to try them. Ive heard of people using Bosh platinum's but I haven't.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
I Use Standard Cap Rotor And Wires And Like Them Real Well. I Used Ac Plugs
JUST HAPPY TO BE ALIVE. |
i strictly use AC plugs, and i either go with AC or B-W for the cap/rotor/wires. All my motors are stock tho.
]'76 K10 Short Step WORK IN PROGRESS '81 C10 Longbed, 250/SM465 '93 Dodge W-250 X-Cab, Cummins NV4500/NP241, D60 front, D70 rear '05 Yamaha Grizzly 660 4x4 Southern Bowties Member |
#13 |
i swear by OEM ignition parts and oil filters just part of my anal personality
so many trucks so little time!!! |
#14 |
Garage Queen Material
i like msd parts and ngk plugs
#15 |
All MSD except for the Bosch Platiniums.
#16 |
california fill
glad you have ruled out accel because their stuff sucks! Ive had good luck with a lot of borg warner and niehoff stuff even though I dont like using it.. Never seen or used a GM cap & rotor but I bet they are nice. MSD must be good too...
pc |
#17 |
I like msd ignitions, taylor wires, and autolite plugs.
Youth soon passes away, but immaturity can last a life time. |
#18 |
Gettin It One Pice At A Time
just wondering, what makes AC DELCO plugs so great?
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
#19 |
Right turn Clyde
Its what the factory uses, most ACDelco parts are pretty good parts.
http://www.acdelco.com/html/ab_main.htm and http://www.acdelco.com/html/hb_main.htm
