Old 11-17-2004, 07:44 PM   #1
chevybill
chevybill's Avatar
Talking v 8 in six mount position
Are there any problems with running a v8 (350) in the 6 cylinder mount position? Will the distributor hit the fire wall or do you have to fabricate a wider fan shroud?
Thanks for the replies everybody.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-17-2004, 07:57 PM   #2
crazy longhorn
Fabricate till you "puke"
It bolts right in, the dist is a little tight if you run the HEI, but does work. Up front, I used the 73 up waterpump & accessories, to get the fan into the shroud(without a bunch of spacer). Here are a couple shots http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-17-2004, 08:21 PM   #3
steve75104
Another 69-20 years later
Is the alternative to move the engine further forward? If so, how difficult is that?
steve75104 is offline   Reply With Quote
Old 11-17-2004, 08:30 PM   #4
71swb4x4
71swb4x4's Avatar
The 4x4 fan shroud is deeper.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-17-2004, 09:38 PM   #5
chevybill
chevybill's Avatar
Talking
thanks for the useful replies, everybody.
perhaps one on the smaller style distributors will work without any problems,
will 1 or 2 of those electrical cooling fans take the place of that wide shroud?
would it be better to use both shroud and fans, gets hot down here in MS in the summertime.
looking at about 350 hp and 400 ft. lbs of torque for the engine.
Old 11-17-2004, 10:12 PM   #6
Slams_58
here is a pic of how close the HEI fits to the firewall when you have a 350 in the I-6 spot
We have a few pics of before and after the swap here
Slams_58 is offline   Reply With Quote
Old 11-17-2004, 10:13 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
hope thats Dubies hand and not yours, unless dubie is under the wrong name again
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-17-2004, 10:16 PM   #8
dubie
dubie's Avatar
oh damn, I just noticed that! yeah it's mine I keep forgetting our home computer is signed in under her name all the time
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
