So I called up a good friend of mine, who works at the local Auto Electric shop. I asked him "This may sound crazy, but my alternator is draining my battery, does that sound right?" First words out of his mouth "Is the 12v+ constant on the #2, and the switched 12v+ on the #1 wire?" "Uhh, I recently put on a new plug, let me check....NO!! THANKS MAN!!!" "No problem bro"
I can't beleive something THAT easy was the fix!! Makes me mad I rewired my truck...but I guess I did good, cuz all those splices looked like trash anyway. In all sorts, I'm good to go now! I told you guys, when there's a problem with my truck, it's 9 times outta 10 CAUSED by me (or the me before me; my dad) ![]() |
#2 | ||
Workaholic
11/15/04
![]() Glad ya got it fixed though ![]() |
Haha, I DIDN'T touch any wires...the plug literally disintegrated when I touched it, so I put a new one on...guess I flipped the wires inadvertantly. Yeah, you and me both!
#4 | |
Workaholic
![]() Yesterday I drove mine at night for the first time in a quite a while and the headlights and dashlights flicker badly going down the road but not at idle ![]() |
#5 | |
Happy to be here
![]() Join Date: Mar 2000
#6 | |
Workaholic
BTW, the temp and volt gage needles shake like mad when this happens--could be a cluster/circuit problem? |
Gentleman Jim Driver
Sounds like a bad ground...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#8 | |
Right turn Clyde
I would get some terminal electric contact cleaner and clean up the connection. Where the headlight and the connector are. Take the wires out of the plastic connector, use a small wire brush and the cleaner to get all the corrosion off. Put it back together. I did this and it helped a lot. I would just randomly go out or constantly blow the low beam light on the driver side. That fixed pretty good and the light was a little brighter.
That may not fix your problem but Im sure it wouldn't hurt to try it.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
