Old 11-17-2004, 10:22 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Radiator options???
What radiator would be best for a daily driver with the following?:
350 cu in
Tuned port injection
700R4 tranny
373 rear gears
Vintage Air
Oh yeah, I almost forgot.... A lot of highway driving in Texas
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-17-2004, 10:48 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
I would prefer a 4 core if I had the choice. My 307's 3 core never cooled too well on our 100 degree days. I'm sure it could have used some work, but still, might as well go with a 4 core if you are replacing one.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-17-2004, 11:17 PM   #3
Mudder
Mudder's Avatar
Most local shops have 4 cores for under or around 150. ya have to change the little dealies they sit on.
Mudder is offline   Reply With Quote
Old 11-18-2004, 12:58 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I never had an overheating problem with my oem 3-row, and we get over 100* here, and rarely to 110*+. But it went bad recently, and I got a 4-row from Radiator.com. It fit the existing mounting pads just fine... My only beef was I had to trim the shroud (minor) because the heater hose nipple was too close to the core...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-18-2004, 10:43 AM   #5
powdercoats
1-800-max-cool is where i bought my copper 4 row. However a late model camaro alum. radiator (up to 96) will fit but you'll have to move the mounting brackets (3row brackets)
powdercoats is offline   Reply With Quote
Old 11-18-2004, 07:35 PM   #6
Wootdog
Wootdog's Avatar
Camaro Radiator Picture?
Not to get on anyones post, but I need to see the radiator hose connections for one of those Camaro radiators. I have an LT1 and it has become a pain in the backside as far as the hookup is concerned. With the four core chevy truck radiator. The inlet by the T is only 1 1/4 inches and the bottom radiator connection is 1 3/4 inches. So I have a standoff made of metal that is two differnet sizes. so to speak that is 1 1/2 inches and the other end is 1 3/4 inches. Hope that makes sense. What I am getting at where is the connection on the passenger side (right) and is it on the bottom of the radiator? Thanks, Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 11-18-2004, 08:01 PM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
I have used radiatorbarn.com several times with great luck. I'd use a 4 row just because you can and they aren't that much more.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 11-18-2004, 09:40 PM   #8
Sweet72
Sweet72's Avatar
Wootdog,
the pass side rad hose on my 95 firebird LT1 is on the bottom, and drivers is on top. If I understand you right you have to adapt from 1-1/2 to 1-3/4. I'm not sure how the 67-72 rad. will work with the LT1 reverse flow. What about the small (about 3/8 to 1/2 in.) radiator return hose coming off the intake manifold? I'm assuming you're using a '90's engine. If that's the case, I think I'd use a impala or f-body rad.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-18-2004, 10:30 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I agree completely. Kinda hinted at it in my post above, just didn't actually say it.
- Mike -
RIP El Jay
Old 11-18-2004, 11:57 PM   #10
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Got my new 4 row for the 71 at autozone. Paid more than radiator.com, but was probably the same stuff from Mexico. Real good radiator though. Never have had it overheat up here in blazing WA. hehe. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
