Old 11-17-2004, 10:57 PM   #1
blazerslave
blazerslave's Avatar
Lower AC Vent location spec
Does anyone have the assembly manual diagram of where the lower AC Vents go and what size the holes are? I have a '72 Blazer and I am adding factory AC and I need the info!
"If you choose not to decide . . . you still have made a choice."
blazerslave is offline   Reply With Quote
Old 11-17-2004, 11:35 PM   #2
71swb4x4
71swb4x4's Avatar
Here are some pics, hopefully they will help you a bit
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-18-2004, 12:12 AM   #3
midyearvet@aol.
I took an extra set of bezels and cut the inner tube off so bezel fits up flush to dash. Trace around inside of opening and cut a hole 1/8" bigger all the way around. Cut notch on top of hole per picture for upper screw clip and you are in business. I used a similar process for center outlet.
Hope this helps
Rick Ca. 1-4274x4
midyearvet@aol.com
midyearvet@aol. is offline   Reply With Quote
Old 11-18-2004, 12:33 AM   #4
blazerslave
Thanks!
Good info!
Old 11-18-2004, 01:18 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by midyearvet@aol.
.... Trace around inside of opening and cut a hole 1/8" bigger all the way around....
If you use a Sharpie to trace with and cut outside the line you will have the extra space you need....
