Old 11-17-2004, 11:03 PM   #1
RODSBYT
RODSBYT's Avatar
pics. exhaust routing over 6" drop axle.
Has anyone routed exhaust out the rear with 6" rear drop coil spring rear with early classic super track bar? 67-72 trucks?
any pictures would be a big help.
Thanks RodsbyT.......
RODSBYT is offline   Reply With Quote
Old 11-18-2004, 07:09 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Well, it's not exactly what you were looking for, but it is a 5" drop with an adjustable trac bar. But I think you can see what needs done on the drivers side to clear a super trac bar (the whole piece moved toward the front of the truck). Passenger side looks like it would easily clear. This is an LMC rear exit kit.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-18-2004, 07:46 PM   #3
RODSBYT
RODSBYT's Avatar
thanks good picture
very tight clearance my track bar goes all the way to the pass. side control arm. your right thou the drivers side is what ive been fighting.
thanks again RodsbyT.....
Old 11-18-2004, 08:58 PM   #4
glock35ipsc
This is the same system I will be using when this thing goes back together, and I will also be using the super trac bar then too. I will just need to shorten the pipe the goes over the axle at the back of the muffler about 3/4" - 1" and it should work fine. Passenger side is no problem with either bar.
Bob
Old 11-19-2004, 08:16 PM   #5
RODSBYT
RODSBYT's Avatar
Does your LMC kit pipes hang way below the frame after the trans crossmember?
I have had a bad time with the local shops bend pipes.
Old 11-19-2004, 08:58 PM   #6
glock35ipsc
They were actually too snug to the trans x-member, and I had to tweek them a little to get them to hang 1/2" - 3/4" lower. All in all, the kit fit really nice.
Bob
Old 11-20-2004, 08:36 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I don't know fellows, I'd like to see a picture of this myself.
My 454 needs 2.5 exhaust and there is no way I could get the pipes over the axle with my 6 inch drop and super track bar. I wound up just dumping in front of the axle, which I hate.
Old 11-25-2004, 07:29 PM   #8
Truckhead
18436572
Truckhead's Avatar
I got 2.5 exhaust all the way out with my ECE 6inch drop. Will post pics soon.
Truckhead is offline   Reply With Quote
Old 11-26-2004, 11:47 AM   #9
GreyHoundSteve
Im curous to see this as well. My exhaust now is dumped at the rear with a minor drop but its already tight and i was thinking i wanted to go bigger with my pipes and drop the rear ALOT more. If the bed was raised would this eliminate some of the clearance problems or is it just a trac bar issue? TX firefighter, i know a real good exhaust guy in Keller if your looking for someone local who makes great bends.
GreyHoundSteve is offline   Reply With Quote
Old 12-13-2004, 08:15 PM   #10
see ten
WTB this ad
see ten's Avatar
Exhaust pics
We're interested, lets see some pics.
see ten is offline   Reply With Quote
Old 12-14-2004, 08:36 PM   #11
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
This is tricky. I have Duramax short headers, and basically I've tried many different exhaust set-ups the best I found is this cutting a 4" hole in the side of the frame welding in a 4" schedule 80 pipe for support(sort of at a angle), and going the the outside of the frame right away. I have the CCP bolt in rear c-notch, with the bump stops in and the exhaust is tight up against the bottom of the bead floor and touches the rear end, when aired out. I will have pictures soon. I plan on removing the bump stops and making a small tub for the exhaust to go up in. I like rear exit exhaust. So it's all worth it to me.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 12-21-2004, 10:37 PM   #12
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Here is something for the extremely lowered trucks. Go to the 3rd page of the new items.
http://www.earlyclassic.com/catalog....ry=New%20Items
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 01-14-2005, 08:57 AM   #13
frogsmakr
frogsmakr's Avatar
ttt
frogsmakr is offline   Reply With Quote
Old 01-15-2005, 01:25 AM   #14
BK
BK Built
BK's Avatar
im getting my exhaust ran out through the back bumper, but everything will be above the frame, under my tranny crossmember, through my trailingarm crossmember, over my trailing arms, over my rear axle, under the notch, back down and under the frame, then out the bumper... i lay frame so cant have it hanging... ill get pics asap
BK is offline   Reply With Quote
Old 01-15-2005, 08:06 PM   #15
Rollie396
someday it will be done!
Rollie396's Avatar
I wonder.Would routing the pipes through where the pic shows (hope you don't mind glock) maybe allow more clearance and eliminate the track bar issue?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 01-16-2005, 01:44 AM   #16
BK
BK Built
BK's Avatar
i believe it would help, but then im not sure, but my panel the gas tank is there, so that would be a problem... if you have a cab gas tank or a fuel cell, should work great.
Old 01-16-2005, 10:09 AM   #17
bagged72blaz
Got L.E.D.s
I'd like to use Bassanis X pipe in my system but I don't have room for it.
Old 01-25-2005, 09:35 PM   #18
loweredd
www.loweredd.com
loweredd's Avatar
This is an 84, but, I have 3" exhaust ran, and it clears with my cab on the rocker. The exhaust goes all the way to the bumper, then is angle cut so you cant see it........
come to think of it, I lay exhuast tip too. ROFL
loweredd is offline   Reply With Quote
Old 01-25-2005, 09:36 PM   #19
loweredd
www.loweredd.com
loweredd's Avatar
Oh wait, you dont have a huge hole in your bed.......this picture might not help.
Old 01-27-2005, 06:44 PM   #20
GenIIIShorty
JUNK COLLECTOR!!!!!
GenIIIShorty's Avatar
that's quite a hole you have going on there.......what's your plans? one solid tub accross the whole bed? interested in this too, i plan on setting my truck on the frame at shows with bags, way down the road, got a some bodywork to do before i worry about that.....
baby
The dark side! 2000 XLT PSD F-250 4x4! Offroad package
1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3
GenIIIShorty is offline   Reply With Quote
Old 01-27-2005, 09:08 PM   #21
loweredd
www.loweredd.com
loweredd's Avatar
[QUOTE=GenIIIShorty]that's quite a hole you have there.....[QUOTE]
Uh, thanks for noticing. LOL
I will use regular aftermarket steel wheel tubs, and rolled Suburban ribbed floor for the middle of the bed, welded in, and ground down smooth, so it looks like the bed floor is bubbled up. SHHHHHHH, dont tell anyone.
Old 03-01-2005, 10:26 AM   #22
bagged72blaz
Got L.E.D.s
Here's mine I need to tub for the X-haust to go any lower, and keep rear exit X-haust flex pipe is temporary!
Old 03-04-2005, 02:34 PM   #23
1974gmc
In Progress
1974gmc's Avatar
are those import mufflers?
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 03-04-2005, 05:25 PM   #24
C-10volvo
C-10volvo's Avatar
fart cans??
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 03-04-2005, 09:34 PM   #25
72MARIO
72MARIO's Avatar
Buzzz Bombs ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
