Old 11-18-2004, 02:22 AM   #1
BurnoutNova
BurnoutNova's Avatar
more cab swap questions
ok, so i was all set to buy a 3/4 ton 2wd cab for my 71 k10. the guy backed out, so now i need to look for another cab.
i might of found one, but its a 2wd 69 gmc cab.
ive been told the 1/2 ton 2wd cabs mount diffrently than 4x4 cabs. what will i need to do to make a 2wd cab fit on my 4x4 frame???
thanks, zach
BurnoutNova is offline   Reply With Quote
Old 11-18-2004, 04:46 AM   #2
GMCPaul
Thumbs up
If the 2wd had a 4spd or a big block motor it will have a bolt in high hump center section and then after you install your 4X4 high hump there won't be any difference, if its not off a 4spd or big block truck it will have a low hump built into the floor and you will need to cut the low hump out and bolt in your high hump. That is the only difference between 2wd & 4wd cabs. What is different is the mounting cushions you place under the cab when installing it 4wd & 3/4 & 1 ton trucks all use a much taller cab mounting cushion than 2wd 1/2 tons.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-18-2004, 11:53 AM   #3
LT4XTREME
This is not the first time I've heard about the taller body bushings on the 4x4,3/4 ton, and 1 ton trucks, this makes since to me to raise the body for larger tires and because this is still being done on the new Chevy HD. The question I have is if the cab is raised then the bed would need to be raised to keep the body lines matched up and I've been under several of these trucks and have never noticed a spacer under the bed (I wasn't looking for them at the time)
LT4XTREME is offline   Reply With Quote
Old 11-18-2004, 12:08 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
The taller mounts are compensated for by lowering the bracket on the frame. On a 2wd 1/2 ton the rear cab mount bracket is even with the top frame rail. On 3/4 tons and 4x4's, it is positioned below the top of the top frame rail. Hence no need for bed or front clip shimming.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-18-2004, 12:29 PM   #5
Mudder
Mudder's Avatar
Seems like it would be easier to just shim the bed and front clip, than to change the cab mounts.
Mudder is offline   Reply With Quote
Old 11-18-2004, 12:49 PM   #6
LT4XTREME
I guess that would put the screws to cutting down a lwb 3/4 ton frame to make a swb 1/2 ton frame unless you used the 3/4 ton body bushings or changed the frame brackets. (sorry to hijack the thread)
Old 11-18-2004, 12:54 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes but if you have the skill to cut down a frame, the cab mount issue should be a no-brainer.
Old 11-18-2004, 01:55 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I installed a 70 2wd 3/4 ton cab (low hump) on my 71 3/4 4wd. I used the bolt on hump as a template and cut the low hump out and used self tapping bolts. Fit perfect. I replaced my bushings w/ poly bushings at the same time.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
