Oil Pressure - "Driving" me crazy
Need some feedback on some findings. When accelerating, my OP drops to 15-30 PSI. Under hard acceleration it will stay there a while until I reach cruise. No problems while cruising, 60 PSI like all normal. If I'm going 60 and I pump WOT, Oil pressure drops from 60 down to 30 PSI. I've even seen it get as low as ZERO from a stop but return to 60 once in cruising state. When I take turns or come to a stop, pressure will drop to 15 PSI. Anyone?
Yeah, it's got oil in it. Mobile 1. ![]() |
Maybe the oil pickup fell off of the pump...
Youth soon passes away, but immaturity can last a life time. |
What do we get for $10?
Or maybe the pickup screen is plugged?
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() |
posibly its to low, thats what it sounds like to me anyways, but pick up screen could be it too
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Slots go on anything!
have you changed out the sending unit? I would try that first, as it would be easiest and cheapest.
1974 Jimmy- 5.3/4L80e/NP241 |
Right turn Clyde
Check the oil level, make sure its level. Buy a mechanical oil pressure gauge just to verify the findings. Could be the bearings are about ready to go but it could be other things. It could be a bad gauge, sending unit, wire connection or mechanical malfunction. Also it might be a good idea to pull the valve covers and check the oil returns. Then you will get to see more of what is going on after the valve cover comes off.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#7 | |
Being as the motor has less than 5k, I'd hope its not something such as the bearings. But we will see. |
