Old 11-18-2004, 10:03 PM   #1
super72
super72's Avatar
Shift Pattern
I have a 72 4X4 with I believe a np203or 208. Does anyone know the pattern that they go in. You know which is first in order down to last. Thanks
super72 is offline   Reply With Quote
Old 11-19-2004, 07:42 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
To have a 203 or 208 it would have been swapped in. The 203 is hi loc, hi, neu, low, low loc. Not sure on the 208 but the 205 should be (dash)4 lo, neu, 2 hi, 4 hi (seat).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-19-2004, 03:05 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
A 208 would be 2wd 4hi neu 4low...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-28-2004, 07:10 PM   #4
4x4Poet
Lets get you straight first. You no doubt have an NP205. Only a stupid PO would have swapped in a 203/208. Check out Off Road Design's NP203/NP205 transfer case guide. Then compare with what you have under the 72. Report back as needed.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
