Old 11-19-2004, 12:30 AM   #1
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Progress!
I was supposed to get this stuff a few months ago, but my wife and I have been involved in purchasing some land to build a house. Now that we've got that over with, I can use some of my money for "my" toys!
I finally ordered my bags, valves and air tank Tuesday from *****************. The UPS man dropped it off tonight (Thursday). Installation begins Monday since I have the week off for Thanksgiving.
Now that I have the valves "in hand" I can take the blueprints I've been working on to the machinist and have my valve manifold started. It'll kinda be like this but with 1/2" NPT connections and will mount my GC Extreme 1/2" valves. Should be pretty neato!
I can also finalize the template showing where to drill the mounting holes in the frame for the rear bags. I've had a couple people express interest in those. Sorry to ramble, I'm just excited to be DOING something!
Here's a couple pix...front A-arms and spindles mocked up to check fit, and a rear bag in place.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 11-19-2004, 12:38 AM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Looks great and I bet you are very excited to be on air soon! Your chassis looks sweet.....
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-19-2004, 01:57 AM   #3
moodybo
moodybo's Avatar
how much did the new parts set you back! to your door?
moodybo is offline   Reply With Quote
Old 11-19-2004, 02:08 AM   #4
MrShelley
Too Many Clubs Club
MrShelley's Avatar
4 Air Lift bags, 8 GC extreme 1/2" valves, and 5 gal. tank
$601 total with shipping
Old 11-19-2004, 02:15 AM   #5
moodybo
moodybo's Avatar
why the two valves per wheel? Only needs one to inflate/deflate per wheel right? I am still gaining knowledge on the air ride!
Old 11-19-2004, 02:18 AM   #6
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Check this thread
I posted a link to a pic that should make everything more clear
Old 11-19-2004, 09:39 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool stuff! Keep the progress pics coming.
Old 12-02-2004, 11:15 AM   #8
Iron-Butt
454 club
Iron-Butt's Avatar
Great info!
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-02-2004, 12:24 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
This might clear things up for the 2 valves per wheel question. (This is for a 2-tank, 2-compressor, 4-way system)
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-02-2004, 01:35 PM   #10
Chris~GS
the GC and most other diaphram valves are "one way" they are designed to only have air flow through them one way... so you will need a fill and a dump, you can make a very nice manafold with parts procured from home depot as well.. i have put 15000 miles on my system with little to no problems
Chris~GS is offline   Reply With Quote
Old 12-02-2004, 01:59 PM   #11
GreyHoundSteve
Do they make two way valves? If not them someone should. Im sure a two way valve could be engineered and produced at a better price than two one way valves and it would simplify and clean up the system. Of course ..... i dont know anything about valves.
GreyHoundSteve is offline   Reply With Quote
Old 12-02-2004, 02:03 PM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
Yes, they do make 3-position valves which is what I'm using on my truck. Here's how you'd plumb that type of system.......
Old 12-02-2004, 06:43 PM   #13
luckydog
< Fav Place on Earth!
luckydog's Avatar
Has anybody seen a 3-position manual valve? Doesn't need to be air suspension designed, just a normal valve will do.
Horsepower is how FAST you hit the wall, torque is how HARD
luckydog is offline   Reply With Quote
Old 12-02-2004, 11:27 PM   #14
jlaird
jlaird's Avatar
Slammed67,
Got two questions on that first diagram you posted. First, is the coalescing filter also known as a watertrap? Second, what would the use of the optional toggle switch on the pressure switch be used for?
thanks
jlaird is offline   Reply With Quote
Old 12-02-2004, 11:32 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
What you guys are missing with the valve situation is we are working with air pressure. Since the air tanks are normally holding more pressure than the bag the air flows from the tank to the bag. Not because the valve is a one way valve, but because the pressure is greater on the tank side.
To understand this think of it this way. If your bags were filled to 80 pounds and your air tank was at 30 pounds the air would flow from the bag to the tank.....
Old 12-02-2004, 11:37 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by jlaird
.... is the coalescing filter also known as a watertrap? Second, what would the use of the optional toggle switch on the pressure switch be us....
Yes the filter they have pictured is there to trap moisture coming out of the compressor.
I am assuming the "optional" switch would be a safety feature to prevent the compressor from coming on in the event of a pressure switch failure....
Old 12-03-2004, 01:13 AM   #17
Bryce M
They do make 3 ways but they are more expensive about 150 per valve compared to 70 bucks for (2) 1/2 inch extremes
Wont you ride my white horse
Its symbolic of course
Bryce M is offline   Reply With Quote
Old 12-03-2004, 12:37 PM   #18
Slammed67
Progress = 0%
Slammed67's Avatar
That and it just allows you to shut off the compressor(s) if for some reason you don't want it running.
Old 12-07-2004, 02:04 PM   #19
luckydog
luckydog's Avatar
I was thinkin of a valve that used two separate lines. One on, both off, then the other on. We have one at work on the pallet machine that's used for some little air cylinders, but it's got dinky ports. I think this valve would work perfect for an easy simple, reliable suspension set-up.
Old 12-07-2004, 06:34 PM   #20
Shev
Head Peon
Shev's Avatar
3 way (or 3 position) valves, otherwise known as "spool" valves are known to stick...not saying they don't work, but just about everybody that I've known that has used them at one time or another has switch over to a "pilot" type valve (2 postion~open & closed)
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 12-07-2004, 07:41 PM   #21
luckydog
luckydog's Avatar
Are the ones that stick electronic or manual?
Old 08-07-2007, 07:41 PM   #22
oscareltemblo
oscareltemblo's Avatar
Re: Progress!
So these are 73-87 style a-arms and spindle with what year rotors and calipers? Was it a direct bolt on or didyou have to modify or fab something?Did you need the 73-87 crossmember?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 08-07-2007, 09:31 PM   #23
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Re: Progress!
Holy crap this thread is old!
oscareltemblo-
I swapped all of the front suspension from a '76 truck. The only thing that didn't get swapped is the crossmember, it's the original '68. The spindles are 3" DJM's for 73-87 trucks.
Old 08-07-2007, 10:47 PM   #24
oscareltemblo
Re: Progress!
ok thanks I just had to make sure ....
