Old 11-19-2004, 02:13 AM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
How long does an aluminized exhaust last?
now i know there are many factors to this, but in general, if a truck is driven daily, say in colorado, how long should an aluminized dual exhaust last? (without major problems with it. ie- rust holes, etc)
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 11-19-2004, 02:54 AM   #2
Mudder
Mudder's Avatar
I would say after a year you will start seeing minor surface rust.
Mudder is offline   Reply With Quote
Old 11-19-2004, 07:34 AM   #3
tom hand
CCRider
tom hand's Avatar
Do they use salt in Colorado? This exhaust is 15 years old and was a daily driver for 10 years
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-19-2004, 09:21 AM   #4
1978steven
1978steven's Avatar
You might be able to fight the rust off for a little longer if you paint the exhaust setup with some high heat paint. I just had my exhaust done at a local exhaust shop here in DFW and they paint all the aluminized setups they do after the install. They used a good high heat aluminum but they also do them in black. Just a thought......
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 11-19-2004, 10:40 AM   #5
Paul72
Paul72's Avatar
Here in the salt belt, mine lasted 9 years. One tail pipe fell off - weld rusted thru. Of course this wasn't a daily driver either. Only about 15k in those 9 years, with less than half in the winter.
I agree with 1978steven - paint/coat the welds and it should last quite a while.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 11-19-2004, 10:54 AM   #6
StingRay
StingRay's Avatar
I get about 10 years in daily use and failure is usually at a weld.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 11-19-2004, 10:58 AM   #7
Mudder
Mudder's Avatar
I was thinking headers........ Daughters Blazer has aluminumised exhaust and they have been on there for a good 10 years and still look good and solid. The welds will rust if not covered with something.
Old 11-19-2004, 03:20 PM   #8
junkyardjohn
junkyardjohn's Avatar
OUT HERE IN THE DESERT THEY SEEM TO LAST FOREVER. I'VE HAD THE ONE ON MY DAILY DRIVEN BLAZER FOR THE LAST 8 YEARS, & IT STILL LOOKS LIKE NEW, BUT BACK IN MICHIGAN YOU WERE LUCKY TO GET 2 WINTERS OUT OF EM. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-28-2004, 03:08 PM   #9
4x4Poet
The metal's guage is a factor, as well. Here in Montana snow country, some exhaust shops use 18 guage aluminized pipe. Doesn't last as long as it should. One of the better shops in my town uses 16 guage pipe. They found the cost difference negligible to the longevity enabled. I wonder if the comments about welds failing first might have something to do with thinner guage pipe not enabling a thick enough weld to resist rust thru. Just conjecture. Using SS clamps also helps some.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 11-28-2004, 04:00 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If he knows what he's doing, the weldor should produce a 100 percent penetration weld. It sounds like they may be using poor grade filler material.
There's a shop here in town that uses coat hangers. I'd imagine his welds will fail much sooner than the pipe he's welding.
In this climate, the aluminized system will last longer than you want to keep the vehicle. My high school driver, a Camaro that I built up in 1988, still has the same exhaust system on it without repairs.
