Old 11-19-2004, 02:47 PM   #1
co-necked
throttle linkage...
My stock throttle linkage isn't working for my new carb. Weighing some options, either a new cable set up, (pricey, I like the jegs/lokar setup) or I think the edlebrock part# 350-8012 looks like it'll work. Its an ext/adapter. Just gathering some info and opinions....
thanks
(1970 custom10)
co-necked is offline   Reply With Quote
Old 11-19-2004, 02:56 PM   #2
Super Duck
Chevy Nuttttt
Super Duck's Avatar
put one in from a later cablr truck. $5 at a junk yard
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-21-2004, 03:57 AM   #3
co-necked
will i have to change me peddle set up? Take the whole thing from the junkyard? Will I have to make any new holes? It seems like it....
Old 11-21-2004, 04:55 AM   #4
cableguy0
what kinda of carb are you running the stock throttle rod can be modified to fit. the pic is crappy but u can get the idea on how it needs to be bent to fit. thats a 750 edelbrock carb in the pic but im using a 750 holley now and didnt have to change it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-21-2004, 08:14 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The cable setup is going to get real involved because your truck has the rod type of pedal.
It's real easy to modify the factory rod to fit a different carburetor. If you do, you can use lengths of 1/4 steel rod available at any hardware store. If you can't weld, measure and cut everything and take it to a muffler shop and have them weld it for you.
Old 11-21-2004, 10:27 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What kind of carb, was the truck originally an inline, small block or big block...what's in there now? How does it not fit.
I've done a few things to a few trucks to get them to work.
Old 11-21-2004, 10:59 AM   #7
Longhorn Man
Here's the one on my old GMC...
Old 11-22-2004, 01:44 AM   #8
co-necked
It had the stock carb on it. SB350 V8. I put on a holley 670. I have very limited play in my peddle.
thanks for the pics
Old 11-22-2004, 08:32 AM   #9
70c10
67-72 Addict!
70c10's Avatar
After I look at that pic, I realized my throttle rod is reversed with the 90 degree bend at the carb.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-22-2004, 08:47 AM   #10
Tx Firefighter
Sounds like you may need to shorten it to get some pedal travel back. There should be some adjustment in tht stock rod. If not enough, you can shorten the rod slightly with a hacksaw and MIG welder.
