11-19-2004, 07:01 PM | #1 |
rear window?
Is it hard to swap in a sliding back glass? Also my seal looks good can I reuse it?
Thanks and tips would not be wasted
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-19-2004, 07:09 PM | #2 |
Signals in the bumper.
Its easy. I swapped my slidder out for a solid glass awhile back. We put a rope in the seal where the cab goes into it and that helped open the seal up. Then, with my dad pushing on the outside and me pulling the rope out as we went along it went smoothly. We started in one corner then slowly moved around the glass.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
11-19-2004, 07:56 PM | #3 |
iIswaped my solid window for a slider 15 yeras ago. I reused the origional rubber. It was pretty straight forward. myself I perfer the slider . Alot cooler for a black truck with no air.
11-19-2004, 10:06 PM | #4 |
both my c 10s have sliders that were swapped in from solid glass. Both times that i did this i used the old gasket over.. I Used a couple of flathead screwdrivers to get the job done although the rope trick works too im told
so many trucks so little time!!! |
11-19-2004, 11:51 PM | #5 |
Stepsides RULE
Wow, after reading this and other posts, i want sliding glass!!! How much does it cost?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
11-20-2004, 12:18 AM | #6 |
Gettin It One Pice At A Time
hijack! my driver side slider window was broken by vandles and I was wondering if it is posable to put in just a new slideing window its self? be cheeper then the $160+ for new window
matt
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
11-20-2004, 12:25 AM | #7 |
The slider windows are around 100.00 from many sources jcwhitney acme lmc and so on.
11-20-2004, 01:56 AM | #8 |
I know of a guy locally (Kirkland) that last time I checked had a few used sliders for sale. If you want I could PM you his #.
Or I guess since he hands out business cards that say "73-87 Chev/GMC truck and 60's Pontiac parts" I could just put his # here - (425) 827-9318. Sometimes you get killer deals, sometimes you got to barter? Depends on what he's parting at the moment.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
11-20-2004, 07:52 AM | #9 |
I just took my slider out & installed a solid glass. Its pretty simple, but a helper makes it easier. Dont forget a spray bottle with dishsoap & water...corn
