Old 11-19-2004, 11:08 PM   #1
kerjer19
1988 suburban - need help
I was looking at buying a neighbors 1988 suburban 350ci 4wd. It starts fine and idle greats. However after putting it in gear it does not want to accelerate. It will get up to about 30 mph. He says he thinks its the fuel system. I was wondering if anybody could possibly give me a clue as to what it may be. Thanks
Kerjer19
kerjer19 is offline   Reply With Quote
Old 11-19-2004, 11:39 PM   #2
gn4u2c
gn4u2c's Avatar
sounds more like timing or cam issue. If it was a fuel problem it would run great then just die out real quick (completly) not hit 30 and just hang there. Is the tranny shifting ok? check the fluid. check the base timing set to 8 btc (best power ) force advance and monitor it to see if all is well there.
I would assume it is efi and stock unmodified. If it has been changed post up so we know what we are dealing with.
gn4u2c is offline   Reply With Quote
Old 11-19-2004, 11:48 PM   #3
Bowties
My guess is a clogged catalytic convertor or otherwise restricted exhaust. My wife's Saab acted the same way and that's what it tuned out to be. Good Luck!
Bowties is offline   Reply With Quote
Old 11-20-2004, 12:14 AM   #4
kerjer19
Thanks for the advice. I will look at those areas next time I get over there. As far as mods, there are none. Still stock with TBI. Again thanks for the info.
Old 11-20-2004, 11:05 AM   #5
gn4u2c
gn4u2c's Avatar
convertor is good advise also the will get red hot when driving if bad.
Old 11-23-2004, 05:21 PM   #6
bisquik65
bisquik65's Avatar
That is a common problem with the 350 tbi engines . Your problem is in the distributor. Pull it out and change it. Try to turn it out of the motor and it will be tight. Look at the flat base on it and its probally bent from a motor being changed. The chain hits the base and will bend it up. . I had one give me that same problem and i spent a ton of money on it and nothing changed,Swaped the dist. and that was it.
bisquik65 is offline   Reply With Quote
Old 04-08-2005, 04:21 PM   #7
mrdood
mrdood's Avatar
Lightbulb
FYI ... I know this is an Older thread, BUT, in my own quest to find this single wire connector to disconnect for setting the Base Timing, I have been looking on the PASSENGER Side (I was off by about 2.5 feet) .... My connector was on the DRIVERS side engine compartment firewall near the windsheild wiper motor.
1979 K5, 4x4, 400 w/edlebrock intake/carb, NP203, 6" suspension, bushwacker fullcut-out flares, 37x14.5-15 Toyo M/T, skyjacker dual stabilizers, pro-comp nitro9000 shocks, Hooker Headers-2.5" dual exhaust w/X-pipe, and more to come.
mrdood is offline   Reply With Quote
Old 05-05-2005, 10:58 PM   #8
ragtopcamarovt
Just another thought.
Symptoms mean a lot when diagnosing a car problem. However I still try the easy things first just incase. Fuel filter especially on a fuel injected motor can cause a very sluggish motor.
Gus
ragtopcamarovt is offline   Reply With Quote
Old 05-06-2005, 06:04 AM   #9
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
8 degrees? Any problems with detonation setting it there? Does it really make that big of an improvement?
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
