Old 11-20-2004, 12:57 PM   #1
wessscott
wessscott's Avatar
headlight switch
I have a 70 c10 and want to change the guages. How do you remove the headlight switch kob on the end. I see the windshield wipers have a set screw but dont see one on the headlights. Any help is appreciated.
wessscott is offline   Reply With Quote
Old 11-20-2004, 01:02 PM   #2
squirel
squirel's Avatar
there is a button on the switch which needs to be pressed and then the knob will pull out. reach up behind the dash and feel around on the switch the button is round just hold it in and pull the knob out.
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 11-20-2004, 01:03 PM   #3
purple gas
there's a little button on the switch.. If you stick your hand and feel on the top of the switch you'lll feel a teeny tiny little knob that you can push down.. Push it down and pull out the switch like you were turning on the lights but it will come right out . It's easy once you figure it out
purple gas is offline   Reply With Quote
Old 11-20-2004, 02:11 PM   #4
wessscott
wessscott's Avatar
Thanks for the info I will do that.
Old 11-20-2004, 04:02 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
They forgot "First disconnect the battery"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-20-2004, 11:02 PM   #6
ChevyDude
Does anyone know where a new Headlight rod can be purchased? My truck has the switch but no rod.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
