Old 11-21-2004, 12:34 AM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Bedcover progress...
I finally painted the bedcover and installed it tonight. I will need to come up with some weatherstrip and shocks. The reason I painted it black is because I will be painted the top section of the truck black this winter sometime. It may help me sell it easier in the spring. Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 11-21-2004, 01:47 AM   #2
longnlow72
longnlow72's Avatar
did u make it? ive been thinkin of making my own also, how tough was it? did u just make a frame then a peice of aluminum over that? the more info the Better
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 11-21-2004, 01:53 AM   #3
68LSS1
68LSS1's Avatar
Yes, must have more details. How much does it weigh? What type of hinge and how did you secure it? I'm definately building one also but was planning on doing it out of composite (kevlar/carbon fiber) material with a couple Autoloc actuators operated off the key fob.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-21-2004, 01:55 AM   #4
CG
BlahBlahBlah
geeze your gonna sell that? ok im sitting down...what you gonna ask for it?
Old 11-21-2004, 10:23 AM   #5
FuelCellGuy
FUEL CELL GURU
longnlow72 and 68LSS1,
The frame is 1" square aluminum tubing. The "skin" is .090 sheet aluminum. It is attache to the frame with 3M 1" wide VHB tape (Very High Bond). The tape works great. It is hard to see in the photo but, the cover has a seam in the middle running side to side. I couldn't justify the price of one sheet of 6' x 8' aluminum. It would never get to me undamaged. The hinges are homemade and operate like a trunk hinge. That is the reason for the small section mounted to the front of the bed. I will take some more pics later today of the hinge area.
CG,
It will be reasonable. Probably in the 12,500-13,500 range. It may sell and it may not. Crews is delivering a 2WD drive Blazer frame to me next weekend. I will be converting the 4WD. I am more interested in a 2WD Blazer, than my truck. If I can get me a carport built this winter, I will probably keep both.
later, Mark
Old 11-21-2004, 11:44 AM   #6
Randy70C-10
Randy70C-10's Avatar
That looks great!!
Randy70C-10 is offline   Reply With Quote
Old 11-21-2004, 12:17 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Looks awesome!! I like the low, flat, flush look.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-21-2004, 01:46 PM   #8
chevyboy55
chevyboy55's Avatar
Fuelcell guy,
Will that tape hold up to the weather stress of a daily driver? Also what about using sheet metal as compared to aluminum? (thinking cost here) It looks awsome, Good job!!
chevyboy55 is offline   Reply With Quote
Old 11-21-2004, 03:29 PM   #9
68LSS1
68LSS1's Avatar
Looking forward to those pictures FuelCellGuy, TIA. About how much do you think it weighs? And do you have any links or info on the VHB tape? What were your reasons for using this as opposed to welding (since you have those capabilities)?
'68 Short Step
Old 11-21-2004, 08:05 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks really clean.... I was wondering if that ride ever sold..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-21-2004, 08:23 PM   #11
FuelCellGuy
FUEL CELL GURU
chevyboy55,
I had another cover before this one on my truck for about a year and a half and drove it 180 miles a day, five days a week. The key is preparation. Both surfaces must be ground with 80 polishing disc. Then, Clean with lacquer thinner, put your tape on one side, peel back the corners, lay your aluminum on the frame and line it up. Then pull the tape backing off from between the frame and aluminum and apply pressure as you work your way down. I think the corrosion factor of sheetmetal would make it a poor choice.
68LSS1,
The cover weighs about 75 lbs. I used the VHB to prevent warping from welding. It is a lot easier to clean up as well. Here is a link to the 3M websites product test results page. http://multimedia.mmm.com/mws/mediaw...ccc9G&OyFqiG_- THe part number I use is 4910. I couldn't find it on the site. I get it from one of my suppliers.
Keep the questions coming. Later, FCG
Old 11-21-2004, 08:40 PM   #12
BOSS
Just here to help
BOSS's Avatar
Mark that is looking great!
BOSS is offline   Reply With Quote
Old 11-21-2004, 08:45 PM   #13
longnlow72
longnlow72's Avatar
Originally Posted by FuelCellGuy
chevyboy55,
how would that be a poor choice once it is primed, painted, etc it would be just like the rest of the truck
Old 11-21-2004, 08:47 PM   #14
FuelCellGuy
FUEL CELL GURU
I guess that would work but then the holding strength of the tape woujld only be as good as the paint adhesion. It might work.. Later, FCG
Old 11-21-2004, 08:53 PM   #15
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Looks awesome!
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 11-22-2004, 02:51 AM   #16
68LSS1
68LSS1's Avatar
That link said I didn't have access but you gave me enough info to find it thanks. Link on 3M VHB tape.
They also say the 4932/4952 works on powder paints and there are others that work on painted surfaces. Any experience with these?
'68 Short Step
Old 11-22-2004, 05:49 AM   #17
co-necked
Thumbs up
that looks great...extremely clean
co-necked is offline   Reply With Quote
Old 11-22-2004, 07:49 AM   #18
68C15
blood type; Retumbo
68C15's Avatar
so how did you work around the area of the rear stake pockets? this is the reason I cant find an aftermarket tonnau (sp).
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 11-22-2004, 08:53 AM   #19
FuelCellGuy
FUEL CELL GURU
68LSS1,
The 4910 is the only tape that I have had any experience with.
68C15,
I made the frame to fit in between the rear stake pocket area. The top material sticks out to catch the top of the bed rail.
Later, Mark
Old 11-22-2004, 10:40 AM   #20
GreyHoundSteve
That cover looks great. I think ive seen your truck before. Im at Meacham field alot and i thought i saw a truck very similar to yours in Ft. Worth a few weeks back. I think it was parked at a metal working place but i was too busy staring at the truck to really notice. Was that you?
GreyHoundSteve is offline   Reply With Quote
Old 11-22-2004, 10:46 AM   #21
FuelCellGuy
FUEL CELL GURU
It couldn't have been me, I haven't ventured that far with it yet. I am a bit apprehensive about air ride. I need to get over it. I am always worried about blowing a line or something. Later, Mark
Old 11-22-2004, 10:53 AM   #22
GreyHoundSteve
I thought it might not be since the suspension and rims looked different but i also didnt think there were probably two pink 67's in TX.
Old 11-22-2004, 12:05 PM   #23
71swb4x4
71swb4x4's Avatar
pink? It's not pink. I would call it peach maybe, but definetly not pink.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-22-2004, 07:58 PM   #24
GreyHoundSteve
Peaches are orange and red ..... it looks pink to me, maybe not cadillac pink but too close to call anything else unless you have a paint chart or box of crayons handy.
Old 11-22-2004, 08:02 PM   #25
Alexis
Member since 2000
Alexis's Avatar
Don't let them get you with the pink truck FCG..........i once used a camera that made my orange truck look pink. I didn't hear the end of it on the board for a long time.
P.S.
it does look pink :p
Alexis is offline   Reply With Quote
