11-21-2004, 09:25 AM | #1 |
Ebay Heads Up!
If you own a 68 do not fall for this bezel!
I did and the guy keeps running the item and will not refund even when I proved him wrong. He does not even own a truck! This is for a c-60 and maybe other large trucks not our pick-ups! The plastic bag one is the guy claims for 67+68 and the box one is the one that fits all the trucks I have. Notice the smaller diameter of the bezel. Thanks to TIM for the Info. This does fit a 67 and I have seen them on a 68 c-60 potato truck. The seller is half right.
1968 Chevy 4x4 307 4 speed Last edited by GMC AMI; 11-21-2004 at 11:14 AM. Reason: Sraight facts. |
11-21-2004, 10:35 AM | #2 |
Hey Mike, A 67 does take a small one it is not the same as a 68-72. Not for sure if the one you have pictured is correct but a 67 does have a small one. Tim
11-21-2004, 11:07 AM | #3 | |
1968 Chevy 4x4 307 4 speed |
11-21-2004, 11:08 AM | #4 |
The 67 style does use a different ignition bezel....whats the part number?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
11-21-2004, 11:45 AM | #5 |
Gm #
The seller hides the # in photo. He did not send in original wrapper, just an envelope. I am sure he goes to gm dealer and buys there only to sell on eBay.
The # is #3908807 stamped on the bezel.
11-21-2004, 11:52 AM | #6 |
Part number is for 67 trucks all models except G model diesels.
Also for 68 -, 02 models and also 69-72 C30, C930-c35 cowl models...seller didn't list enough I guess. The parts book actually list it as fitting all model in 68 also...but I know that's not the case. Your best off to list it as a 67 ignition bezel...you'll be fairly accurate that way. Anyone who buys it should know what its for then.
