Old 11-21-2004, 02:33 PM   #1
crustysarge
Valve cover grommets
I need to order some stuff form the States and was thinking about changing them hard old valve cover grommets on the 72. Has a 350.
Anybody have a P/N or other info I could use at Autozone.com for the following grommets:
PCV, Air filter tube, oil filler neck.
Thanks if you got somehting.
crustysarge is offline   Reply With Quote
Old 11-21-2004, 04:24 PM   #2
incoma
incoma's Avatar
pvc grommet is #730537 vendor id 42059 Its in the help section, I don't think those are online. They have 2 that will work, one has a square flange the other is round. I bought both, and couldn't find the other part number. I think this is the round one but am not sure.
incoma is offline   Reply With Quote
Old 11-21-2004, 06:58 PM   #3
Sweet72
Sweet72's Avatar
http://www.gmpartsdepot.com/store/pr...Category_ID=56
Not Autoxone but this might help.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-26-2004, 04:26 PM   #4
crustysarge
Thanks.
