11-21-2004, 03:05 PM | #1 |
The LuvShack Garage
Help - Never Done This Before
PUT A DOOR ON THIS MORNING, I HAVE HEARD THEY ARE A B!TCH TO ALIGN,
I HAVE NO DOUBT IN MY MIND THE RUMORS WERE TRUE, IT IS RUBBING AT THE BOTTOM WHEN I OPEN IT, I ONLY HAVE THE HINGES ON, NO LATCH OR THAT STUFF, NOT SURE WHICH WAY TO GO FROM HERE, HAVE PIC'S
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-21-2004, 03:25 PM | #2 |
I'm no expert, but I'd bet you need a handfull of shims
11-21-2004, 03:52 PM | #3 | |
The LuvShack Garage
ALL MY NUTS AND BOLT WERE REPLACED WITH A KIT FROM TOTALLY STAINLESS, THEY DON'T CARRY SHIMS, ANYONE KNOW WERE I CAN GET STAINLESS SHIMS, AND SINCE I HAVE NEVER DONE THIS, WHAT SIZE ARE SHIMS, WHAT DO THEY LOOK LIKE, DO THEY COME IN KITS
11-21-2004, 04:40 PM | #4 |
What was I thinking??
You mite beable to get some from pepgirls or NAPA, Checker even try the Help area that most stores have. maybe a Auto body supply store.
I just looked at my 71 and I don't have any shims..The door latch thing does though.
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
11-21-2004, 04:50 PM | #5 |
Looks like your low on the entire door. Not a lot of people on this morning, and I am not a expert, but try the following and I'm sure you may get a few more pointers.
Back the bolts out till they are loose and put a wedge between the bottom of the door and the rocker to help support the door. I did not see a bottom gap in the asy manual, but the fender to door gap is .16 +/- .09" It should be close to the same on all sides. Try using a couple of paint sticks or 12" wood rulers for the wedge between the door and the rocker. Go by your bottom body line to match up, not the top line of the bed, door is taller and not sure you can go by it. Try keeping the rear of the door the to the same gap all the way up ,them snug the bolts. On a blazer the body will flex and you may also have to add shims to the body / frame attaching points if the windshield frame does not match the top frame of the door. Adding or removing will allow the door opening to get wider or smaller, but I would start by getting the door up off of the rocker and go from there.
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s Last edited by A few 72's; 11-21-2004 at 04:55 PM. Reason: typo |
11-21-2004, 04:57 PM | #6 |
looks to me like you need to put something under the front like a wood door shim or something like that that wont ding the door.. withall the bolts on the piller loose pry up on it,,,get the bottom gap'd right then tighten the bottom hing,, then let the top of the door fall back or ahead to line up the back& bottom... this is very hard for me to explain so I hope this helps are those goodmark doors??? I hade to use the allmighty hammer to get mine to fit the way I wanted
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
11-21-2004, 05:05 PM | #7 |
a few 72's ya beet me to it (I'm a slow typer) LOL buy the way luv I have never had to use shims on a door,,, you live down south right??? maybe I'll quit my job come down and help ya LOL cailing for snow this week you just buy the rolling rock LOL!!! let me now if I can help any other way My 4x4 is about the same way and I can take some pics to better discribe
11-21-2004, 05:11 PM | #8 |
The LuvShack Garage
CETHERN - REALLY WANT STAINLESS SHIMS SINCE ALL THE BOLTS ARE,
CHECKED MY 70, NO SHIMS ON HINGES, JUST THE LATCH ASSEMBLY SHAN - I WILL TRY THAT, I HAVE RAISED DOOR ONCE ALREADY, BUT IT WAS TUFF BY MYSELF AND I DON'T THINK I MOVED IT VERY MUCH KING - THANKS, ROLLING ROCK EH, BY THE WAY THOSE ARE RUST FREE OE CALI DOORS FROM A 72 CST PICK UP TRUCK, NICE AREN'T THEY
11-21-2004, 06:32 PM | #9 |
It looks like the gap near the windshield post is good, which leads me to believe the door is pretty much in the correct spot. I would try shimming the back of the body up assuming that you don't have a stack of shims already in the first body mount location on the bed. If there are any shims at the mount, take them out see if it makes a difference.
11-21-2004, 06:43 PM | #10 |
The LuvShack Garage
THANKS, GEE I'LL CHECK THAT, DOES IT MAKE A DIFFERENCE THAT NONE
OF THE LATCH CONTROL STUFF IS IN PLACE JUST A LIL CURIOUS
11-21-2004, 06:47 PM | #11 |
The latches can be adjusted, I would just work on getting the gaps nice. You might want to put the vent window while adjusting the gap between the a pillar and the door frame.
11-21-2004, 07:06 PM | #12 |
The LuvShack Garage
Thanks Gee, I Was Going To Put The Vents In.
11-21-2004, 08:05 PM | #13 |
FUEL CELL GURU
I have never seen shims used on door hinges. There should be enough adjustment without them. Just my experience. Later, Mark
11-21-2004, 08:19 PM | #14 | |
The LuvShack Garage
THE BODY MOUNTS DO AFFECT THE ALIGNMENT OF EVERYTHING ELSE.
11-21-2004, 09:13 PM | #15 |
Get you a handfull of paint stirring sticks from a paint store. Loosen hinges and slip paint sticks between bottom of door and sill. Adjust + or - sticks until body creases on door line up with body creases, then tighten hinges. Take sticks out, open and close door a few times to make sure it hasn't moved
11-21-2004, 09:23 PM | #16 |
The LuvShack Garage
3ott, Thanks, Ur The Second Person To Mention Stirring Sticks,
Gonna Get Some On The Way Home From Work Tomorrow, Maybe The I Will Get The Fender, Other Door, Other Fender, Cowl And Tailgate Put On, Then I Get To Unbox The Goodmark Cowl Hood.
11-21-2004, 10:32 PM | #17 |
Got the cart before the horse trying to align the doors without the body in alignment---what I mean by that is the firewall will tend to sag a bit if not attached to the frame via fenders/rad support, inner fenders etc. You would be much better off having the top in place and bolted down before you try to align the doors. Key is the rear door edge being in perfect alignment with the leading edge of the rear quarter----next key area is the windshield frame alignment to the front edge of the door frame when the vent window mounts---then the proper clearance with the outer rocker. The original GM assembly manual has the plant use shims to get the proper alignment of the body to frame to allow for the doors to align to the body----but without the top holding the firewall in perfect alignment to the rear quarters, you may be waisting your time and making work for yourself.
11-21-2004, 10:50 PM | #18 |
The tub should stay in the same position with the top on or off as long as the rocker boxes are solid, the cab section is a fairly rigid assembly when they are rust free. The whole front end just kinda floats there hanging off of the cab. Body mounts play a big role when trying to fit everything together. Once you get your doors algined, drill some small holes through the hinges into the body and doors so that if you have to take them off they will be easy to realign later.
11-22-2004, 12:14 AM | #19 |
PROJECT 7DEUCE
I had the same problem and used the advice that gee gave.... It worked very well and I had no front clip on...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-22-2004, 04:48 PM | #20 |
My 72 has good rockers and rocker boxes and when you take the top off thier is a noticable change in the door gaps. I would definitly have a top on while alining the doors the rocker boxes work to keep the blazer from flexing alot but the tub does flex not to mention that blazer has whent threw a lot as far as restoring ti goes so you may have a little bitt of body aslighnment problems to work out so you may need mount the top and front clip to get the doors lighned up I would hate to see you put the top on later and have to redo the doors and fenders to get the gaps write. for shims you can use stainless washers and just cut a slot in them they work grate that way and you can hide them by grinding them down to shape them so they cant be seen.
Earl 68 2500 4x4 GMC Burb |
11-22-2004, 04:49 PM | #21 |
The LuvShack Garage
FOUND PART OF THE PROBLEM, I THINK, DID PASSENGER SIDE TODAY AND IT
WENT SMOOTH AS GLASS, I THINK IT IS A BODY MOUNT ISSUE, TOOK TAPE AND MEASURED FLOOR TO CENTER OF WHEELWELL OPENING ON BOTH SIDES OF THE FRONT, IT WAS OFF 1/2", YOU CAN SEE IT REAL GOOD IN PIC #3, I'M GONNA LOOK INTO THIS LATER, I'M KINDA TIRED, SEE THE NEW PIC'S. *P.S. REPOP FENDERS, OE CALI RUST FREE DOORS AND TAILGATE, HONEST
11-22-2004, 04:58 PM | #22 |
Make sure when you align your doors you leave then a little bit high in the back where the door striker plates are. You have to account for the added extra weight of all of the internals in the door and glass and such. I agree that you shouldn't install the front clip before you adjust the door. Do what you are doing. Work from stationary object "quarter panel" forward. Doors and then fenders. Tighten your core support bolts last. You may have to shift the front end over left or right to make the hood fit in the hole properly. Once the hood closes right then tight the core support bolts up.
11-22-2004, 05:49 PM | #23 |
Wow Luv2, that rig sure looks good! Even with th black primer. I wish mine was that far along.
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP [B]1972 Chevrolet K5 Blazer RIP 1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP 1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP [B] 1995 Chevrolet Tahoe 2D [B] |
11-22-2004, 06:10 PM | #24 | |
The LuvShack Garage
ONLY DONE THE WORK IN THESE RECENT PIC'S, PO DID MOST OF WORK.
11-22-2004, 07:31 PM | #25 |
Actually found a page in assembly manual giving measurements of the gaps and it talked about how the body mounts are the key
