11-21-2004, 07:38 PM | #1 |
user # 2756
front clip bolt question
I'm getting ready to install, fenders/inners/core support and other items attached to the core support on my 71, hopefully next weekend. I have two different length bolts as shown in the attached pic and need to know which goes where, for the following locations:
1. battery tray to core support 2. battery tray to inner fender 3. core support to fender 4. core support to triangle support (right and left) 5. fender to above triangle support 6. fender to inner fender 7. grill shell to fenders 8. grill shell support to core support and hood latch mechnism Can't think of any others. here's the two bolts:
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
11-21-2004, 07:52 PM | #2 |
The short ones are used in 1,3, 4, & 5. The longer ones are used in the rest of the locations, except the lower hood latch which uses a 12 point screw.
Jim Last edited by JimKshortstep4x4; 11-21-2004 at 07:54 PM. |
11-21-2004, 07:55 PM | #3 |
user # 2756
Jim, Thanks!
11-21-2004, 07:58 PM | #4 |
You are welcome, I just removed a Blazer saddle today and I believe that what I told you is pretty accurate.
Jim |
11-21-2004, 08:04 PM | #5 |
user # 2756
When I took the front clip off the 72 C30 I wasn't paying too much attention myself and figured I'd just ask the great members of this board the question. My 7 yr old actually took most of the bolts off.
11-22-2004, 11:22 AM | #6 |
Your 7 year old is lucky, you are starting him off the right way! (Maybe I should not assume that your 7 year old is a boy).
Jim |
11-22-2004, 12:11 PM | #7 |
user # 2756
Jim, Your right, 2 boys. Here's the 7 yr old, he likes the air ratchet:
11-22-2004, 12:21 PM | #8 |
I could have used his help!
Jim |
11-22-2004, 09:23 PM | #9 |
Jim, if you need some of those bolts come on over. I have a bunch of them.
11-22-2004, 10:52 PM | #10 |
Jim,
Let me know when you get ready to start. Id like to come over and check it out. Richard |
11-23-2004, 07:43 AM | #11 |
user # 2756
I know you do Randy! Richard I'll let you know. Still getting everything staged. Probably happen the weekend of the 4th and 5th.
