Old 11-21-2004, 07:59 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Couple more joint questions.
Are all carrier bearing mount's bent in the middle like the one pictured below? I do have another one I can mount in there if I grind off the rivit's. The top carrier bearing mount should have the fat lipped side facing the rear of the truck correct? Any help would be great ..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-21-2004, 08:25 PM   #2
kwmech
Should be flat--my 68 gmc has a bracket on the diff side of the cross member that bolts on the top side, then the carrier bearing hangs from it.
Old 11-21-2004, 10:07 PM   #3
Paul72
Paul72's Avatar
First, make sure you have some good quality stuff. Next, roll it tight....
OOPS sorry, not the joint you were talkling about!
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
