Old 11-21-2004, 09:49 PM   #1
2low72
easiest way to check rear end gear ratio?
I know I've seen this in a thread before but couldn't find it.
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 11-21-2004, 09:57 PM   #2
Paul72
Paul72's Avatar
Jack up the rear end and spin the tire. Count the number of revolutions of the driveshaft in 1 revolution of the tire. If both tires are off the ground, one revolution of the tire is needed. If only 1 tire is off the ground, spin it 2 times.
The number of driveshaft revolutions is your ratio (Just over 3 = 3.08, Almost 4 = 3.73, etc.)
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 11-21-2004, 10:06 PM   #3
2low72
That's what i thought but wasn't sure
Old 11-21-2004, 10:16 PM   #4
dwaite72lnghrn
I tape a string on the drive shaft, Then mark the tire with tape at the bottom. move the truck 1 tire revolution (a helper here will make it easier). Climb under and count the number of wraps the string has made and you have it. three wraps and a little 3.08, three and a half 3.5, three and 3/4 3.73, and so on.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-21-2004, 10:42 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I say count the teeth. The lube is probably 20 + years old anyways.
Old 11-21-2004, 11:29 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
Divide the ringear into the pinion!!!!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
