Old 11-22-2004, 06:40 AM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Suspension Tests
How do I test to see if I need to replace the pitman arm? As far as I know everything is stock with about 174000 miles. I know I need an idler arm (already have). I still need to get inner / outer tierods, adjuster sleeves, and pitman arm (I guess) along with upper and lower ball joints. Do I seem to be missing anything suspension wise besides a-arm bushings? Center link shouldn't be bad I wouldn't think. Ive never rebuilt the front-end components before. I read Mikes article and it helped some. Looking for some help
I would like to really take it all apart and do a total rebuild. New Cross shafts, clean up the a-arms and install new bushings but I dont have time or money for all that right now. Im pretty close but its already about 350 and getting higher. So there needs to be some stopping point albeit 3/4 the way into it.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-22-2004, 05:12 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you think it hasn't been replaced, and you are already replacing the idler arm, I would do both at the same time.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
