11-22-2004, 02:10 PM | #1 |
nice engine parts for sale
i have a new in the box scat crankshaft..it is the 9000 series steel crank,3.48 stroke...take$190 shipped..i have a set of new in the box scat 4130 5.7 rods with arp bolts i will take $190 shipped for..
and i have a set of new in the box speed pro hyperetic .030 pistons that i will take $90 shipped for...or get it all for $450 shipped to your door..as i said all parts are brand new still in scast boxes....good deal here folks... also have a solid cam and lifters..it is an elgin 1090p-$60 set chrome valve covers and timing cover-$25 mallory dual point distributor,has old cable drive on it for tach...no cap...$50 just stuff i need outta the way,took up a new hobby and have no room..thanks |
11-22-2004, 04:45 PM | #2 |
Resident Young Old Dude !
What's the tech specs on the Camshaft?
11-22-2004, 04:56 PM | #3 |
295 duration and 537/555 lift...3000-7200 rpm...good all around cam...
11-22-2004, 05:19 PM | #4 |
do you have a pic of the valve covers? + shipping to 30041?
11-22-2004, 05:50 PM | #5 |
i will try to get pics of valve covers,i been having trouble with my cam..they are the regular old chrome set with timing cover,ill ship for $5 extra,they are in good shape.thanks
11-25-2004, 01:11 AM | #6 |
valve covers sold,everything else still for sale
11-27-2004, 11:23 AM | #7 |
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7937641441
posted them on ebay with pictures,theres the link,if ya want them better jump on it..... |
11-28-2004, 03:41 PM | #8 |
i also have for sale a set of roller rockers,stud girdles and poly locks ill take $275 for,have a set of 487 heads,ported,2.02/1.60 valves,screw in studs,600 lift triple crower springs,take $350 for them...stuff needs to go..thanks
11-29-2004, 03:16 PM | #9 |
also a chrome carter fuel pump ill take $35 for..stuff needs to go
11-30-2004, 01:26 PM | #10 |
bump it up----stuf needs to go
11-30-2004, 08:15 PM | #11 |
A WORK IN PROGRESS
will these parts work in early 90's roller block. non LT1. also what brand are the
roller rockers? full roller, what ratio? what compresion would i get if i used 64cc chamber heads with your pistons? i am interested if i can find a roller block for cheap. Last edited by 68 chevy truck-TPI; 11-30-2004 at 08:30 PM. |
11-30-2004, 08:26 PM | #12 |
the parts will work yes,only thing you may have to do is if the block you get is a one peice rear main you will have to have a 2 peice to one peice rear seal adapter,no biggie though,but yes they will work no problem...the rockers are full roller 1.5 crane gold race rockers,have gold stud girdles and poly locks too....i beleive with 64cc heads you would have 10:1 compression or close too it....i dont have a roller block but i do have a 4 bolt 3970010 block already .030 over i d sale
12-01-2004, 03:47 PM | #13 |
speed pro pistons and steel pump shaft sold...heads are sold as well.....i need to sale the crank and rods as well as rockers,good deal..thanks
12-10-2004, 12:17 PM | #14 |
roller rockers,rods sold...crank needs to go
