Old 11-22-2004, 05:19 PM   #1
arkracing
Weekend Warrior
Differance between -
What is the differance between small block and 6cyl motor mount stands???
is there? or is it just the placement on the front end?
will small block mounts bolt into a 6cly crossmember without drilling holes?
I see a couple of guys on here that have a small block on the 6cly mounts...does it raise the motor up or just put it a little further back ??? I just don't want it up in the air (i saw a truck recently and the motor looked way to high up in the engine bay and i couldn't figure out why)
Thanks,
Andy
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-22-2004, 05:27 PM   #2
gr8scott51
gr8scott51's Avatar
Just moves it back. HEI distributor is tight to the firewall.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-22-2004, 05:28 PM   #3
crazy longhorn
Fabricate till you "puke"
the stands are different.... the sb is mounted (from the factory) , 3 1/2" farther ahead than it would be if mounted on the I6 /250 stands. As far as I can see, after 3 swaps(sb on i 6 stands), i see no diff in height. as far as swapping the stands, the same front crossmember will accept either set of stands.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
