Old 11-22-2004, 07:16 PM   #1
72MARIO
72MARIO's Avatar
11 mpg Small block HELP.
Oky I am getting 11 MPG in my C20 Highway. driving it nice and easy in OD. (it's a 84 but I thought it would not hurt to post it here) It's 350 30 over, A lumpy Cam and unknown specs. Performer RPM, 1406 Carb, K&N ,filter, 1 5/8 Headders 2 1/4 duals, HEI with a curve kit, NGK platinum plugs gapped at 45, Taylor wires and a Accell Super Coil. 700R with Stage 2 shift kit and a open 3:54 rear.
Should I expect any better ? When I am driving it in 4 th and I have the Lock up switched on It' basically will not go up hills with out droping it down into 3rd and unlocking the tranny. I was wondering if 3:73 gears might be of any help? That way the motor is runnning in it's power range.
Any help would be Great !
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-22-2004, 07:22 PM   #2
Super Duck
Chevy Nuttttt
Super Duck's Avatar
you are talking about a heavy truck but wit hsome timeing tweeks and carb tweeks you might be able to squeek out another 1 or 2
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-22-2004, 09:25 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What kind of MPG does it get in drive as opposed to overdrive?
Lower RPMs doesn't always mean more MPG.
Old 11-22-2004, 09:25 PM   #4
I agree, you probably need to tweak the carb a bit. What bothers me is your comment about it's lack of pull. My 96 is a stock 350 with 3.42 rear and I can easily cruise at 70 and get about 16-17 depending on terrain. I almost never see it kick out of OD unless I stomp on it, or I get into some serious hills in Tennessee or West Virginia.
You should be able to tweak a bit more out of it, but I get the feeling your cam may not be one set up for low/mid end and you won't be running at peak until way higher RPMs. If that cam is making it lug like that, going to a 3:73 may help with that problem, but I don't think it'll increase your MPG much. To me that's not that big a gear change to where it would matter much.
Old 11-22-2004, 09:27 PM   #5
cableguy0
im with those guys i think your cam is probably too big for your combination and blowing fuel out the exhaust as well as take your power band too high for a street truck
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-22-2004, 09:31 PM   #6
Super Duck
Chevy Nuttttt
Super Duck's Avatar
I agree thats why I said maybe 1 or 2 mpg more is all you can expect
69' SS elky
Old 11-22-2004, 10:20 PM   #7
72MARIO
72MARIO's Avatar
I guess I should consider changing the cam. It's got lots of power in the top end that's for sure! It will throw you right back into the seat. I cant even get traction at the top of first and second gear if I put my foot to the floor and sideway I go.. And in the rain driving it nice It goes sideways when it shifts. I have nott been driving it like that for the last month or so though. I had a Vacume gauge in the truck for a while and in drive doing 100 km is where the gauge said I was getting the best economy. When I put it into OD and switched the lock up on it dropper to the poor spot.
2005 TAHOE DD
Old 11-22-2004, 10:23 PM   #8
72MARIO
72MARIO's Avatar
I have not tried driving it in D yet I just filled up and I am going to try it with lock up and in D and see what I can get out of it.
2005 TAHOE DD
