11-23-2004, 02:46 AM | #1 |
Active Member
hard starting
What's the best cure for a starter that cranks slow when the engine's hot? Heatshield, replace starter, or both? This starter bolts into the bell housing instead of up into the block. I have 2 of the newer starters but would have to replace the bell housing to use them.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
11-23-2004, 02:49 AM | #2 |
Active Member
Please move. Got this question in the wrong place. Thanks.
11-23-2004, 10:13 AM | #3 |
I had the same problem... bought a mini starter and the problem went away!
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
11-23-2004, 12:20 PM | #4 |
Premium Level Member
sounds like the engine itself may be getting hot. That will impede starter from functioning properly.
jakeslim
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
11-23-2004, 04:38 PM | #5 |
I had the same problem replaced the battery, no change , replaced the starter problem gone works great hot or cold
69 c-30 dually flat bed & dump ( best truck ive owned 87 chevy dually 97 1500 classic 89 wellcraft |
11-23-2004, 08:52 PM | #6 |
its all about the +6 inches
Your starter is going out from exsesive heat.
Replace the starter with a new one, and get a heat shield for it. A mini starter would be nice, but not needed. If you don't install a heat shield, the starter will last about 5 or so years in a daily driver with normal (8 to 1) compression and headers. If you get one with a life time waranty, then so be it. They'll replace it when it goes bad. Sometimes, you get lucky and have one last a long time in these conditions. Sometimes they only last a year. Myself, I just got an auto zone rebuilt starter, ran it for 4 years, and it was starting to slow down just a little bit. There is also a chance that your timing is advanced too much. Inplug the coil next time you try to start it hot and see if it still cranks slow. If so, get a starter. If it cranks over fine with the coil unplugged, then time to look into the tist for sticking weights or at least check the timing. |
11-24-2004, 02:55 AM | #7 |
Active Member
Thanks everyone for the replies Cheapest I see a starter is $50. I can rebuild it for a lot less than that. Will also run up to Summit and pick up a heat shield. Was hoping I wouldn't have to pull the starter. Have to work outside and it's supposed to be cold the next few days. I don't think it's the timeing. Set at 10 degrees advance.
