Old 11-23-2004, 04:31 AM   #1
CT-Truckster
CT-Truckster's Avatar
Need Help: Identify these plugs
Somebody tell me what these plugs used to go to on my 84. They where danglin down behind the motor on the tranny. I'm thinking one or both went to the lockup converter? Which someone before me replaced the TH350C with regular old th350, Along with the esc distributor for a non esc HEI, The plug for it was a danglin' too. THese are the only two plugs that weren't connected to anything that I couldn't readily identify what they are for. I guess I need to get me a manual.
CT-Truckster is offline   Reply With Quote
Old 11-23-2004, 08:28 AM   #2
beaterC10
The round plug looks like a kock sensor plug with is not needed since the ESC dizzy is absent. My truck had the sensor on the passenger side about the middle of the block. The four prong plug would be to the transmission, again not needed.
beaterC10 is offline   Reply With Quote
Old 11-23-2004, 09:20 AM   #3
Jonboy
Slots go on anything!
the knock sensor has one large round hole in the middle, and two places that grab the sensor on the sides. The one on the left looks like it went to the oil pressure sender that would have gone behind the distrubutor on that year. I think the trucks with gauges had 2 prongs like that one, and the trucks with lights had one prong, IIRC. The other plug does indeed go to the trans for the lockup converter.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-23-2004, 12:04 PM   #4
dons454s
dons454s's Avatar
Yes I agree oil on the left and tranny on the right
dons454s is offline   Reply With Quote
Old 11-23-2004, 12:40 PM   #5
gn4u2c
gn4u2c's Avatar
100% correct oil/ tranny if you put a lockup unit in be sure to plug it in .
gn4u2c is offline   Reply With Quote
