Old 11-23-2004, 10:50 AM   #1
k5b
suspension lift
I want to put 35"s on my 85 k5 blazer 4x4, would a 4" lift be good enough?
85 K5 Blazer
k5b is offline   Reply With Quote
Old 11-23-2004, 10:57 AM   #2
cochino12
It followed me home?
cochino12's Avatar
4" would be fine as long as you arent doing a lot of wheeling, they may rub a bit if you get the tires really stuffed though.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-23-2004, 11:33 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
I agree, just keep your swaybar on and not try to do too much articulation and it will be fine, especially if you run 8" wide wheels.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-23-2004, 03:56 PM   #4
1972
Majician
1972's Avatar
With 9" of lift on my K20 and my 35's still hit the front fenders when flexing. With 4" you will be able to go to the mall, but I wouldn't run over any curbs. Any semi-hardcore wheelin' would be dangerous to your fenders.
1972 is offline   Reply With Quote
Old 11-23-2004, 04:28 PM   #5
useRc10
useRc10's Avatar
everyone says they will rub, but I have 33s with 2" lift and i can flex it pretty good without rubbing
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 11-23-2004, 04:48 PM   #6
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
It all depends on your wheel width. I run tall skinny Q78x16 SuperSwamper TSL’s (35.5”) on 16x7 wheels with a 4” and ORD ½” heavy duty greaseable front shackles and never had a tire rub yet. The truck finds it’s way onto some pretty precarious trails in the CO mountains too.
This picture is not one of them but does show some flex.
DirtyLarry is offline   Reply With Quote
Old 11-24-2004, 02:02 PM   #7
k5b
I am thinking of using 35x12.50x15 tires on 15x10 wheels. Would that work?
85 K5 Blazer
Old 11-24-2004, 02:11 PM   #8
gn4u2c
gn4u2c's Avatar
You will not have any problems with a 12.50 tire the problem comes in on the 14.50's
gn4u2c is offline   Reply With Quote
Old 11-24-2004, 07:31 PM   #9
k5b
thanks guys.
85 K5 Blazer
