Old 11-23-2004, 01:09 PM   #1
TIMSPEED
TIMSPEED's Avatar
Fuel Cell Install Write-Up with Pics
First order of business was to get the bed off, so we could begin work.
Next, we measured the distance between the inside of the frame rails, which just happens to be 32”. Luckily, my friend had some scrap metal laying around. We used a 32” long piece of 1”x1” box tubing.
Next, we set the cell in, with the piece of box tubing. We decided to put the cell mounting straps on top of the rear crossmember, in order to get the cell to tuck in higher, and farther back. Putting this on, we noticed that we were going to have to make it drop a little lower in the front, in order to make it sit level. So, we got some 2”x.75” c-channel stuff, and we took the chop saw and cut the small pieces that we needed. We just made it so the c-channel would sit in the frame rails (Mostly because we didn’t have a piece long enough, haha)
So, after that, we tacked it on with the wirefeed, and went on to notching the rear bed support, to clear the sending unit. After we measured, we decided that we’d notch out a 5” wide portion, and go up 2” with it. After my friend got done cutting it with the Oxy-Acy torch, I took the grinder to it, and smoothed off the edges.
The next thing we had to do, was measure for the gas door. We decided that we’d cut it on the same plane as the rear bed support notch, except we were going to make it a 6”x6” square. (In my thinking, I thought that I could find a gas door off of a later model truck, and it would be more apt to be 6”x6”.)
After cutting the gas door, we had to remove the stock gas tank, and plumb/wire the new cell. This was fairly easy. Just undo the 8 bolts holding the stock tank to the frame rail (4 in front, 4 in back) and off comes the tank. We were going to pull out the stock metal tubing, but decided not to, because it was bolted to the frame rail along with the brake lines. So instead of unbolting it for nothing, we just decided to remove the rubber hoses that connected the stock tank to it.
Once the stock tank was out, and the lines/wires were removed, we ran the new 6AN braided line right along the inside of the frame rail, and up to the pump. Wiring the cell was fairly simple. We just had to run a new wire from the stock sending unit wire, to the cell, then we grounded the new cell sender to the rear crossmember.
So, now the only thing left to do, was set the bed back on. Now, the only hard part, is getting to the rear bed bolts, (Not the VERY rear ones, but the ones just in front of them) because of where the cell is at, it makes it nearly impossible to get to them with anything other than a SKINNY arm/hand and a boxed-end wrench. Luckily, my friends little brother has skinny arms and hands! haha
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-23-2004, 01:16 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have seen something like that before.....(except, Jeff has pics )
http://www.73-87.com/7387garage/chas...ellinstall.htm
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-23-2004, 01:21 PM   #3
bigblock73
yeller
bigblock73's Avatar
Thumbs up
Good job Tim.
bigblock73 is offline   Reply With Quote
Old 11-23-2004, 01:59 PM   #4
TIMSPEED
TIMSPEED's Avatar
I actually used Jeff's page to install mine. I saved it on my notebook, and took it over to my friends, to show him. The only difference is, I welded my brackets to the frame, and mine isn't as purdy.
See Them Here
Old 11-23-2004, 02:07 PM   #5
Captkaos
Captkaos's Avatar
Nothing a little paint won't fix.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-23-2004, 02:09 PM   #6
slammed_82
Ground Pounder
wires
what wires did you hook up for the sending unit to work thanks looks good by the way hope mine looks as good when done with the install
82 swb
slammed_82 is offline   Reply With Quote
Old 11-23-2004, 02:13 PM   #7
bigblock73
yeller
bigblock73's Avatar
I thought about using steel and welding it, but I wanted to be able to remove it (easily) in case I ever decided to get rid of the cell...or go to a bigger one.
Glad I could help a little, I would like to see the pics before the bed went on.
Old 11-23-2004, 09:53 PM   #8
TIMSPEED
TIMSPEED's Avatar
22
See Them Here
Old 11-23-2004, 09:55 PM   #9
TIMSPEED
TIMSPEED's Avatar
33
See Them Here
Old 11-23-2004, 09:57 PM   #10
TIMSPEED
TIMSPEED's Avatar
44
See Them Here
Old 11-23-2004, 09:59 PM   #11
TIMSPEED
TIMSPEED's Avatar
55
See Them Here
Old 11-23-2004, 10:53 PM   #12
bigblock73
yeller
bigblock73's Avatar
Tim, looks great! Two questions...
1. What is the square hole in the rear frame rail for?
2. Can you get me a pic of the hole in your bed floor at an agle....showing me the distance between the top of the bed floor and the cell itself?
Thanks.
Old 11-23-2004, 10:55 PM   #13
bigblock73
yeller
bigblock73's Avatar
OK, one more question...
3. Did you end up having to notch the bed floor support to clear the sending unit on top of the cell?
Old 11-24-2004, 12:35 AM   #14
TIMSPEED
TIMSPEED's Avatar
1. That was there before. My dad put an OkieRig towbar setup, and apparently cut that through the rear crossmember, in order to route the support beam through it.
2. I don't quite understand What angle do you want? There's about 3" between the top of the cell and the bedfloor.
3. Yes, DEFINATELY. That's what that picture with the 5"x2" is for..that's the notch for the sending unit. 5"x2" is literally the SMALLEST notch possible to safely clear the sender.
See Them Here
Old 11-24-2004, 12:48 AM   #15
ocbaud
Garage Queen Material
damnit! i need MORE MONEY!!!
ocbaud is offline   Reply With Quote
Old 11-24-2004, 12:51 AM   #16
TIMSPEED
TIMSPEED's Avatar
Now you want to cell your tihs huh? The cell was only $175, fittings/line were about $75. The benefits are priceless
See Them Here
Old 11-24-2004, 12:54 AM   #17
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If that is a 16 gallon, how do 30 gallon blazer tanks fit?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-24-2004, 12:55 AM   #18
TIMSPEED
TIMSPEED's Avatar
Haven't a clue...16 gallons is enough for me!
See Them Here
Old 11-24-2004, 12:58 AM   #19
MylilBowTie
Right turn Clyde
Most blazers I remember the tank looks pretty tucked even with a little lift in the rear. I could be wrong wouldnt be the last time lol
Old 11-24-2004, 01:01 AM   #20
BaggedC10
Under construction!
BaggedC10's Avatar
Looks awesome, Tim! More incentive for me to purchase a new frame and start over w/ my truck.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-24-2004, 01:05 AM   #21
ocbaud
exactly how much braided line did you get for $75??
i'll do this next summer.
fuel cell
cnotch frame
add lowering shackles
Old 11-24-2004, 01:41 AM   #22
bagged74
its just $$$$$
bagged74's Avatar
maybe a dumb question, but why not turn it around and run the fuel line out the front instead of the rear? looks real good tho!
bagged74 is offline   Reply With Quote
Old 11-24-2004, 01:54 AM   #23
Russell
Professional Grade
Russell's Avatar
Fits nice with a longbed, don't even need to move the brake line bracket.
I'll be installing a second one on my other truck right away, but doing it with the stock brackets that are on the truck. I used the Blazer brackets the first time I installed one, but it sits a bit crooked. I'll post some pictures in a couple days after I finish.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-24-2004, 02:16 AM   #24
TIMSPEED
TIMSPEED's Avatar
No question is dumb my friend. In fact, a friend of mine did this, because he didn't want people messing with the line..well..that's an easy way to starve a motor. One night, on a hard launch, on the bottle, it went lean, because all the fuel went AWAY from the pickup and caused the motor to hiccup, and BOOM!
Eric,
I got 15' for $50, then a few fittings to run it from the cell to the pump, for $25. 15' is PLENTY of line for our trucks, BTW.
See Them Here
Old 11-24-2004, 03:55 AM   #25
Paso76GMCstepper
Paso76GMCstepper's Avatar
Looks Great
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
