Old 11-23-2004, 05:05 PM   #1
bigunde
Rusty Rockerfeller
another 350 to 454 swap question
just out looking at my 70 and noticed the clutch linkage that goes from the frame to the block.will this still work for the 454?
bigunde is offline   Reply With Quote
Old 11-23-2004, 07:00 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The one ton I just bought had a big block with headers and an SM465. PO pulled the 427 and I noticed the linkeage through the fire wall had been modified. But the z bar was in the correct location.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-23-2004, 07:29 PM   #3
bigunde
Rusty Rockerfeller
heya jim,does that mean it bolts to the same location of the block as the small block?
Old 11-24-2004, 07:28 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'm going to say yes as the guy had the 427 sitting on the 350 mounts/stands.
Old 11-24-2004, 06:42 PM   #5
Nick's683/4
I was trying to find out the samthing and jerry moss told me that it wont and you have to make a new spot for it to mount.
70 1 ton with a 454 and a 4 speed and a np205
Nick's683/4 is offline   Reply With Quote
Old 11-24-2004, 07:58 PM   #6
bigunde
Rusty Rockerfeller
i had my buddy at the chevrolet dealership look up the z bar for those years and it says one number for all engines.
Old 11-28-2004, 12:20 PM   #7
4x4Poet
It's not the z-bar that's differnet between engines, it the length of the rod from clutch pedal to z-bar determined by the frame location of the z-bar bracket, the location of which is determined by the original engine installed. IIRC, 6 cyl have different bracket locations. Yup, come to think of it, I've seen a few wrecked 67-72 6 cyl trucks with the z-bar bracket mounted father forward.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 11-28-2004, 02:51 PM   #8
BAD4X4
BAD4X4's Avatar
You must make sure the block has the hole up front of the oil filter, to spin in the ball for the z-bar. My new 2004 454 I had built by chevrolet didn't have the hole so I had to go with a new 63-67 corvette style set up that skog and dickie sell. Hope this helps.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 11-28-2004, 05:01 PM   #9
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yup if you move the engine to the original V8 position you'll have to move the Zbar too.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-28-2004, 05:03 PM   #10
bigunde
Rusty Rockerfeller
i did notice when i put the big block frame towers in there are no bolt holes already drilled at the bottom.the top lines up fine.
