Old 11-23-2004, 06:54 PM   #1
jamie72
jamie72's Avatar
dana 20
i just bought another blazer, and the dana 20 is in the back in 2 or 3 chunks!
will only dana 20 out of these trucks and blazers bolt in?? will a jeep or internaitnal work??
or do i need to get a whole new setup??
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 11-24-2004, 11:25 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
You can put in an NP205 or even the Rockwell T221 if you find one. You will need the adapter and either lower your existing transfercase crossmember or get the correct one for the NP205. Sorry, don't know whether a Jeep or International one will be the same.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-24-2004, 05:46 PM   #3
jamie72
jamie72's Avatar
so if i got an adapter, and a 205 it will bolt in??
did 465`s come out in 69 blazers?
thanks jamie
jamie72
member #807
www.antlertalk.com
Old 11-24-2004, 06:13 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
I don't know if the 69 K5's had the NP205. Most 69 pickups had the Rockwell T221.
What transmission do you have?
If it is a 4 speed manual, it will bolt right up if you get an adapter for the 4 speed and the NP205, NP205 it will bolt right up. You will need to either lower the transfer case crossmember 1/2" to 1" or get the crossmember that was with the NP205.
I can't speak on if it is an automatic - I assume you will be fine but I am not familar with the adapter differences so I will let someone else address this if it is an auto.
