11-23-2004, 08:12 PM | #1 |
Tell me how to build a tach/vac
I know of 4 different dash possibilities. There may be more.
Gauge, gauge with tach, gauge with vac and gauge with tach and vac. I have a tach dash and would like to add a vac gauge. I know that the tach dash does not have the hole punched for the vac gauge. This is difficult I hear. Is it easier to use a vac dash and add the tach or how would you do it?
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
11-23-2004, 08:24 PM | #2 |
member #16
If you buy the vacuum guage kit from one of the board venders it comes with all of the needed parts.
John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-23-2004, 08:27 PM | #3 |
You either need to get the inner bezel with the correct holes or graft another hole from a doner where it can't be seen when it's all assembled. To be correct you'd need a lens with vacuum on it as well or if you like just polish it clear. I personally grafted the Vacuum part of the lens into my tach lens. It was BIG job but it was 10 years ago when repro stuff was not available and I had Zero money to spend
Saskatoon, Saskatchewan Canada |
11-24-2004, 12:42 AM | #4 |
I built mine using a tach dash. I replaced the lens with a new vac/tach lens, drilled a hole in the backing plate to mount the vacuum gauge, and grafted a doner piece to my inner bezel(the metal tin with openings for each gauge). I cut a hole (about 1 & 3/4 I think) in the tin where the vac. gauge should be, then cut a larger piece from a donor tin that had the opening stamped in it, and epoxied it in place. The doner tin was a regular gauge dash, so I used the temp gauge opening as my donor. I know this probably doesn't make much sense, but anyway, it can be done, and wasn't too hard to do. I can't tell that mine was ever modified. I thought about making a tach/vac dash out of a vac dash that I had, but the opening in the tin for the tach is an odd size, and doesn't match the other tin openings, so I had no donor tin. You can always just cut a regular hole in the tin, but it won't look right at night when your dash lights are on.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
