poker face
A cool and subtle mod
This close up is of the back window in an ebay action.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW The question I have is how is the back window rubber gasket deleted? It looks to me like the glass is urethaned in with a narrow rubber trim, similar to what new vehicles use. There is more involed in the mod than that, I'm sure. The pinchweld is not large enough to accept the urethane needed, and the glass is too small to just set in the opening. Can someone explain? It also looks like the windshield has the same treatment. I want to do this, and would like to know the correct way of doing it.
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month. |
Judging by the height of the glass, it's a chopped top truck anyway. So there could be lots of modifications going on there.
Happy to be here
![]() Join Date: Mar 2000
Longhair is correct. Who else could spot a chopped top so quick. The top on that truck has been chopped. The window channel was modded to accept the flush fit glass....
back window looks like a flush mount ... but the front window looks like a normal gasket to me.
Tyler you're still lurking around here. Hows that cab stretch coming along?
Saskatoon, Saskatchewan Canada |
poker face
Ray, I'm still here. I would like to post answers more often, but by the time I get to the computer, someone has already given my answer, or the answer I am looking for is here already. I'm here quite a bit.
The strech has came back to life after a long pause, but is really no further ahead then when you saw my pics. Now I want to add this to the mix. I have my ideas on how to do it, but would like the opinion of someone who has seen/done it. All I have is mag pics as a reference. Maybe even just an educated guess would give me a different way of attacking it. I guess I am looking for procedure, more than identification. I know it has been modded, but how. That is the million dollar question. I don't want to screw it up and have to throw away the work I have done. This has to be right on, because I don't think there is a way to bend, shrink or massage a windshield and back glass to fit.I've found that out the hard way at work.
If I were to guess I'd say he extended the flange around the rear window for extra surface area, cut a new (and bigger to match the opening) rear window from laminated safety glass (ACARA Glass is pretty good at this. Talk to Darryl) and then masked the black pinch weld primer on tha glass to give a nice border on the glass, then he urethaned it in. If you look close at the top edge of the glass it looks like you can see the line along it's edge where the laminations in the glass are. If I was going to try that that's how I'd do it. Are you still working over at Autocolor?
Saskatoon, Saskatchewan Canada Last edited by StingRay; 11-24-2004 at 12:11 PM. |
#8 | |
Happy to be here
Yeah that back window looks trick. I also like the 3rd brake light. Does anyone know where i can find one of those but with a clear lense?
Too many projects
I'm not a flame kinda guy, but those look really cool.
Jim ![]() ![]() '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
67-72 Addict!
I think those flames look awesome, I wish mine were done in that exact style!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
love that color
#13 |
Why would you want a clear lense? You can use a clear one on the back of the vehicle except as a cargo light or back-up light. I doubt if something like that would illuminate well enough for a cargo light.
#14 |
Cargo Lamp
Here is my cargo lamp, looks amazing in my opinion.
#15 |
poker face
Slogo, that is a different truck. There are no drip rails on the pic you posted and are on the others. Still a very nice color. Do you have any more pics of that truck, or a link?
Ray, I am still at Autocolor, you should pop by sometime.
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month. Last edited by jiggs; 11-25-2004 at 07:37 PM. |
#16 |
F.A.S.T. president
![]() Join Date: Sep 2003
I think the glass is glazed on from the inside as well, look at the glass from within the inside and you will see a black seam around. Any way if its not..... thats the way I would do it if I wanted that look. Just trim up and clean the pinch weld and make a lager peice of glass to be glued on the inside surface of the cab
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
#17 | |
Right now i dont have anything there but i thought an led clear lense 3rd brake light would look trick if i could flush mount it like the guy in the 1st post did. |
#18 |
Half a bubble off!
You should be able to find these lights and housings at any of several hot rod fabrication sites. I've seen them available, but don't remember where. Some guys use them for tail lights, backup lights, and/or brake lights on their hot rods.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#19 | |
Project 7dos
Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#20 | |
Funny enough but i played around with google for an hour one day and couldnt find any of these. If anyone knows a site please post a link. Also, could someone post a link to the orange truck on ebay. I wanted to look at all the photos again. |
#21 |
graphic designer
try picking up a copy of streetrodder. there are lots of vendors that advertize these types of lights.
#22 | |
#23 |
computer illiterate
[QUOTE=jiggs]Slogo, that is a different truck. There are no drip rails on the pic you posted and are on the others. Still a very nice color. Do you have any more pics of that truck, or a link?
that truck cab slogo posted is his.
72 2wd blazer 72 swb 4x4 |
#24 |
Yes it's mine..... just posted cause of the color nice truck. Buy Mine Now 84,000.00 even
![]() just kidding..................................... |
#25 |
poker face
Slogo;
Are you firm on that price? ![]()
