Old 11-24-2004, 08:57 AM   #1
1969K10
1969K10's Avatar
Leaking Richmond T-221 X-fer
I did a search on this transfer case yesterday, and several of you have had problems with them leaking. I'm in that same boat, did any of you ever get it to quit leaking? This filling it back up every 2-3 weeks is getting old, and the facilities guy at work is giving me grief about the oil slick under my truck. If so, what did you do? I currently have this little one way valve out the top that I've thought about replacing with a hose like on my front & rear diff's.
1969K10 is offline   Reply With Quote
Old 11-24-2004, 11:04 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
I assume you mean the Rockwell T221. Mine was somewhat leaky so when I had it out I put in all new seals and made gaskets for every place that should have a gasket. I think I did a good job but guess what, she still leaks! May just be the nature of the beast, I don't know. Mine never leaked bad enough to have to fill with fluid, just a drip or two each day. If yours is leaking that much, I guess you are better off trying to reseal it. The vent on the top of mine is like yours, no hose. If it is clogged that could be causing a problem.
When I put new seals in mine there were three large yoke seals that I bought for $16.81 a piece, Federal-Mogul part number 482164N and two shifter seals at $4.20 each, Federal-Mogul part number 470954 and also states 0.750 x 1.250 x 0.250 on the box below the part number. There were a cheaper brand but the parts guy said those seals looked pretty cheap.
You can buy a kit of seals and gaskets I believe, but it was like $90 I think when I looked. Was easier to just make the couple seals. Some areas use very thin metal shims. I cleaned them up real good and then did reassembly.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-24-2004, 11:14 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Can't recall at the moment if the seals mentioned above covered the adapter also, but there are seals there that you would also want to replace if you go to the trouble of pulling the t/c.
Usually are two bolts inside the adapter that you need to remove to separate the adapter from the transfer case also. I have some pics if you are interested.
Old 11-24-2004, 12:24 PM   #4
chipotledude05
Strategery
You won't ever get it to stop leaking. My dad's truck has leaked since it was new in '65. My '61 leaks as well. Several seal kits later they both still leak. I think that we finally came to the conclusion that while the seals are good, and keep the leaking to an inperceptable crawl, the leaking keeps the output shafts well greased. Other than that, its a good tcase. You'd have a hard time breaking one. So, my suggestion is to do a seal job. That should keep the oil off the ground.
chipotledude05 is offline   Reply With Quote
Old 11-24-2004, 01:03 PM   #5
1969K10
1969K10's Avatar
Rockwell, Not Richmond
Thanks guys! Yeah, I rebuilt the T-case last fall, new seals, gaskets, the whole 9 yards, and its still leaking
I didn't get a seal for the T-case to tranny adapter, so I used ample amounts of liquid gasket - I hate that stuff.
The 2 bolts inside where quite a surprise for someone just learning as they go.
Guess I'll try replacing that one way valve thing and see if it helps any.
Old 11-24-2004, 02:32 PM   #6
1969 GMC
1969 GMC's Avatar
good luck with your quest...my Rockwell did that, then one day started leaking so bad i had to top it off each morning before I went to school. Then came the death clank...it ran out of oil when I was going about 60 mph, not cool. After that it was only a short time til it totally seized up on me (going 60 mph again, lets just say I had to change my boxers when I got home). I opened her up and it looks like every singe bearing in the tcase is shot. Quite a few of the ball bearings jumped out of the races and did who knows what kind of damage to the internals. I am still in the process of swapping in a NP205.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-24-2004, 03:17 PM   #7
1969K10
1969K10's Avatar
Yeah, I read your horror story when I did my search on this X-fer case... Sorry to hear about it, I hope mine doesn't go that route
Old 11-25-2004, 02:15 AM   #8
687980chevy
687980chevy's Avatar
Has anyone tried 140w lube? Or maybe transmission stop leak. I never have just wondering. Mine believe it or not doesn't leak, just a little damp on the case.
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
Old 11-29-2004, 09:05 AM   #9
1969K10
1969K10's Avatar
Yeah, my closed knuckle D44 is supposed to run 85W-140, so I put it in my X-fer to see if it would stop/slow the leak. Hasn't made any real difference.
Old 11-29-2004, 09:54 AM   #10
toddol1971
maybe lucas oil stablizer? It says you can use it up to 100% in diffs & transfer cases. May be worth a try.
All my trucks are gone now. I'll gladly take a free one
toddol1971 is offline   Reply With Quote
