Old 11-24-2004, 11:31 AM   #1
MacGyver
MacGyver's Avatar
Red face 3100 or 3600?
Hello, I was wondering if anyone can tell me the significant differences between the 1948-1953 chevy 3100 and 3600's. Is one bigger? Thanks
Paul
MacGyver is offline   Reply With Quote
Old 11-24-2004, 07:09 PM   #2
crews
It just doesn't matter
As I recall- The 3100 is a 1/2 ton, while the 3600 is a 3/4 ton. I will check my Chevy data book to make sure I am correct.
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 11-24-2004, 08:39 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yup 3100=1/2
3600=3/4
3800=1 ton
Body wise they're the same though,as long as the bed length is the same.So I'm told.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-06-2004, 02:48 PM   #4
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
What would be the differences between the 1/2 ton and the 3/4 ton?
Axle? Engine?
I have a lead on a 52 3/4 ton five-window.
I am thinking about building a "rat rod" with it for now. Is a 3/4 ton too big to do this with?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 12-06-2004, 09:38 PM   #5
Brainchild
Brainchild's Avatar
8 lug wheels and heavier suspension.Prolly a few small things I'm missing,but basiclly that's about it.
The 3/4 ton will work,you could swap it out for the 1/2 ton suspension fairly easy,install late model rear axel,and aftermarket front suspension,or do a frame swap,graft a front subframe into it.There are a lot of alternatives
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-07-2004, 10:58 AM   #6
Apache
Apache's Avatar
the 3/4 ton is probally a long wheel base, but it could be a short wheel base. The 3/4 ton would be a 8 lug where as the 1/2 is a 6 lug. The rear axle will be bigger, and with lower gearing (higher ratio). Heavier springs rear and front, bigger drums and brakes. I dont know if the front axle (the metal beam) is thicker or not, may be. It being a heavier duty 3/4 ton it probally has the 4 speed am I right? Engine should be the same as was offered in the 1/2 ton.
Like brainchild said, you could swap out the 3/4 ton stuff for 1/2 ton if you wanted too. Make it lighter and be a little easier to find parts for (brakes, springs, axles) when/if you need them.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 12-07-2004, 02:32 PM   #7
8t5Silverado
From what I understand it has a 4 speed with a later model six cylinder.
